On a 7962, how do I get one of the side buttons to dial somebody voice mail
Trying to set up an administrator with one voice mail button for 4 voice mail extensions
Everyone's tags (1)
1 REPLY
If you already have the config to dial directly to someones VM in place you would just need to set those as speed dials on the phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
153
