Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
On-net site codes
I am currently bringing multiple sites into CUCM 7, all connected via IP. These sites have overlapping dial-plan's, and changing from 4 to 5 digit dialing is not an option.
I would like to utilize site codes. I found documentation that utilizes route patterns, but I do not see how a route pattern would work as I am not using a route list to reach the other sites. The other sites would essentially be seperated by partitions.
Thanks.
1 ACCEPTED SOLUTION
Re: On-net site codes
One option is to use a translation pattern to strip the site code and send the call to the DN in the proper partition.
Hope this helps.
Brandon
Hope this helps.
Brandon
Brandon,
Thanks for the response. This is helpful.
Would this be a typical solution:
Site A
A-DN-Part
A-SiteCode-Part -> Containing TP's
A-Unres-CSS -> Containing only local route partitions, VM etc.
Site B
B-DN-Part
B-SiteCode-Part -> Containing TP's
B-Unres-CSS -> Containting only local route partitions, VM etc.
A-TP
81.XXXX
Partition -> A-SiteCode-Part
CSS -> B-Unres-CSS
B-TP
82.XXXX
Partition -> B-SiteCode-Part
CSS -> A-Unres-CSS
Thanks for the help!
Yes, that is correct. You would configure the translation pattern with a digit discard instruction of PreDot which would strip the 81 or 82 and then ring the proper extension.
Hope this helps.
Brandon
Thanks so much.
How do you typically handle a centralized Unity implementation in this environment?
I guess that I could have a pilot per site that would have access to the voicemail ports, and all users mailboxes would be site-code + 4digit.
That's one way to do it. You could also use voicemail profiles to mask the DN. You'll also need to turn on Multitenant MWI. See the following post.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc15a65
Hope this helps.
Brandon
286
