On-ramp faxes corrupt, TIFFs incomplete/scrambled
Hello Team,
i cannot receive onramp-faxes properly anymore.
They are corrupt, after the half page the sent TIFFs are just rubbish/unreadable/incomplete.
Looks like i had sort of timing/clocking-problem, had this before with PSTN->FXS-connections and attached faxes, but...i did all i did there to solve this problem.
I have set the clocking options as seen below, usually solved these problems. Not in this case.
BTW i have no timeslips or anything like that:
voip-rt-2#sh controllers e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (846 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
My configuration as below worked wonderful on our former voice router, an 2811 with three BRI-interfaces.
We have moved our PSTN-connection to our new 2921 with an E1 controller. Also the configuration regarding onramp-faxes.
Any helpful input on this problem would be appreciated, since users complain about it, everybody liked this feature before.
Otherwise we would have to implement another faxsolution...the onramp-solution before (as long as it worked!) completely fitted our needs.
And i really want to stay with the former solution. On the new gateway, for sure.
Many thanks in advance,
Andreas
Software on 2921:
flash:c2900-universalk9-mz.SPA.154-1.T1.bin
Software on 2811:
flash:c2800nm-adventerprisek9-mz.124-24.T6.bin
Related configuration:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
voice call send-alert
voice call disc-pi-off
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
 fax protocol pass-through g711ulaw
 h323
  h225 timeout t302 2
  h225 signal overlap
 modem passthrough nse codec g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
  call start slow
  call preserve
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server <IP OF OUR MAIL SERVER> port 25
mta send subject FAX, bitte Anhang (.TIF-Datei) beachten!
mta send filename FAX
mta send mail-from hostname voice-gateway.<OUR DOMAIN>
mta send mail-from username FAX
application
 service FAX-VON-AUSSEN flash:app_faxmail_onramp.2.0.1.3.tcl
 global
  service alternate Default
controller E1 0/0/0
 pri-group timeslots 1-31
interface Serial0/0/0:15
 description ** E1-Port -> TELEKOM **
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn overlap-receiving T302 3000
 isdn incoming-voice voice
 isdn send-alerting
 isdn sending-complete
 no cdp enable
voice-port 0/0/0:15
 echo-cancel coverage 64
 no vad
 cptone DE
 timeouts interdigit 2
 bearer-cap 3100Hz
dial-peer voice 388500 pots
 description ~~~ FAX-DIALPEER allgemein fuer Versand als Mail ~~~
 incoming called-number 388[4,5]..
 direct-inward-dial
dial-peer voice 388520 mmoip
 description ~~~ SMTP-DIALPEER <EXAMPLE> ~~~
 service fax_on_vfc_onramp_app out-bound
 destination-pattern 388520
 information-type fax
 session target mailto:<EXAMPLE@OURDOMAIN.DE>
Flash:
5        12262 Sep 29 2009 20:44:00 app_faxmail_onramp.2.0.1.3.tcl
6         2484 Sep 29 2009 20:44:24 app_faxmail_onramp.ReadMe
7        45056 Sep 29 2009 20:44:48 app_faxmail_onramp_callflow.fm
Everyone's tags (1)
1 ACCEPTED SOLUTION
Try modifying the image
Try modifying the image encoding. I had TIFF files coming through with some of the content distorted or squashed together.. I found changing to the Modified Huffman (MH) image encoding sorted everything for me.
Make this change under the MMOIP Dial-Peer
"image encoding mh"
Other options are
Modified Modified Read (mmh)
Modified Read (mr)
Passthrough
Ben
If you find this post helpful, please rate.
Nobody having a similar issue
Nobody having a similar issue in the mentioned environment...or ideas?
...or is nobody using this
...or is nobody using this feature? I considered it as quite handy...
"image encoding mh"
Other options are
Modified Read (mr)
Passthrough
Ben
Many thanks, Ben, this seemed
Many thanks, Ben, this seemed to solve the problem here too.
No idea why i had no problem with this on the old gateway, but...i´m finished with trying to understand everything in IT meanwhile ;)
315
