Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
On SRST I am not able to call outside and Voice message is not working
I am using CUCM version 7.  Unity express version 7.0. In normal operation all of my configuration is working fine. On SRST from PSTN/Mobile any one can call inside and here atoattendant welcome message and the call can be transferred to any IP Phone.
The issue is while all the IP Phone are on SRST I am unable to dial any PSTN/Mobile number. Also internal calls are not going to voice messages.
I have attahed the running configuration of the Voice Gateway and "debug voice ccapi all" logs on SRST.
call manager ip 172.21.131.162
Voice Gateway ip 10.76.90.254
Unity Express ip 10.76.90.253
Please help me to troubleshot the issue.
Ashfaque.
1 ACCEPTED SOLUTION
Re: On SRST I am not able to call outside and Voice message is n
Calls are failing with no circuit on the outbound dial-peer match to go out the trunk group.  Is the POTS trunk group up, and are these circuits active and able to take outbound calls?  Can you plug an analog phone into these circuits and make outbound calls?
Collect the CCAPI debug again in addition to 'debug vpm sig' in parallel, and you can observe what events are occurring on the analog circuits to trigger the no-circuit.
-Steve
-Steve
Thanks Steve, four circuits were causing problem. Have changed those circuits now it is working ok.
Ashfaque
234
