One DID 2 Bri to ring all phones
I've got 6 7920 and 2 7960 with a uc520 connect. I've got a 2 bri.. no the things is when one of the bri's is called i want all the phone to ring. at the moment a got the bri to forward a call to a hunt group bud that doesn't do it for me. Can someone help me out?
Phone extensions 2xxx
Phone number ONE DID 493440075
Thanx andy
Hall of Fame Super Gold
Re: One DID 2 Bri to ring all phones
The easiest is shared lines, configure same extension on all ephones. That has drawbacks, if you don't like these, you can try a tcl/ivr service that I wrote to blast all phones at the same time:
http://pbevila.fastmail.fm/public/bcast.tcl
Don't think the UC520 will hack that
Actually it does as I have various installations doing it already, with both methods mentioned above.
How do i install that ?? I;m newbie
Shared line is a standard configuration in which you assign the same ephone-dn to multiple phones with : button command. If the line is in overlay on a button I suggest the "c" button command.
"Blast" TCL/IVR service has installation instructions in the file itself.
I know about how to configure the share lines.. You pasted a file in the previous comment how do I use that.?
It's a tcl/ivr service. You can either study first on the cisco website what tcl/ivr is, or just follow the configuration example in the file itself.
I just can't believe that when a outside party is calling it isn't possible to ring all phone's..
Is there no standard way to have one DID with serveral extesions to ring all at ones.!!
A traditional pbx also has one DID and several extesions ring at ones.!! this is even default setting.!!
Greetings
Andy
Well, it *is* possible with shared lines.
Then I wrote the script to solve certain disadvantages that shared lines have.
A blast mode for ephone-hunt has been unofficialy announced for the next cme release.
Well got notice of TCL installed it but getting an error on impleting it.
under Config T i put
application
service bcast flash:/IVR/bcast.tcl
param destinations 201,202,203
after that on the console output i get
Feb 17 23:59:47.583: Could not load IVR script
errno=-1=hifs Failure
Never mind used CAPS when putting it to flash
129
