11-13-2013 02:25 AM - edited 03-16-2019 08:22 PM
Hello
This is probably the most basic question on earth but I am still getting my head around the CME config and how things work, I am from a R&S/Wireless background.
Ok so I have three dual line directory numbers.
ephone-dn 1 dual-line
number 222 no reg primary
name Office 1
ephone-dn 2 dual-line
name Office 2
ephone-dn 3 dual-line
number 333 no reg primary
name Office 3
Each of these is assigned to button one of an Ephone:
ephone 1
mac-address xxxx.xxxx.xxxx
type 6941
button 1:1
ephone 2
type 6941
button 1:2
ephone 3
type 6941
button 1:3
Effectively I want to be able to dial 111 (i.e DN 1) and it also ring Ephones 2 and 3.
I still need Ephones 2 and 3 to have thier primary numbers as setup, I just need them to also ring if someone dials 111.
Someone put me out of my misery and tell me how basic this is to do?!?
11-13-2013 02:55 AM
you can have one shared ephone-dn on multiple ephones.
For instance:
ephone-dn 1 dual
name Shared
number 777
ephone-dn 2 dual
name Primary1
number 111
ephone-dn 3 dual
name Primary2
number 222
ephone 1
mac dead:beef:0001
button 1:2 2:1
ephone 2
mac dead:beef:0002
button 1:3 2:1
Alternatively, you can use overlays.
button 1o2,1
if you don't want to use a second button for the shared line.
Take a look at
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
page 915, section "Shared Line Overlays"
G.
11-14-2013 01:56 AM
I had a feeling it was very simple.
I just added Directory number 1 (which should be 111 in the original post) as a second button on each of the other two phones. When someone dialed 111, it rang the phone which has the DN on Button 1 and also the other two which had the same DN on button 2.
I was trying to overcomplicate it and it ended up being too simple!!
Thanks for your help
