Community Member
one touch call forward
hey all,
im looking for the ability to add one touch call forward to forward to a pre programed number. Is there any way to activate the call forward all option without hitting the soft key?
1 ACCEPTED SOLUTION
Re: one touch call forward
if you have CUCM no way to do so, not the first one to ask for this
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
218
