One voice gateway router, two E1 cards
Hi All,
I have a 2851 router as a voice gateway, with two E1's cards, each going to its own PRI. Currently all outgoing calls go out one E1 interface. How do I split them so calls from X range go out one gateway, and the rest go out the other?
IOS 12.3(14)T4
The E1 cards are S0/3/0 and 0/0/0.
CCM 4.1
Re: One voice gateway router, two E1 cards
It all depends on whether this is MGCP or H323 which you do not mention in your post
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
It is H323
One possible way is :
Have two outgoing dialpeers and one for X range and another one Y range. Now assign the E1 ports accordingly..
Under the outgoing pots dialpeer,
direct-inward-dial
port 0/3/1:15  <===== give your port number here...
Here is an example of one of the existing outbound dial-peers:
dial-peer voice 21 pots
description PSTN Access (Telecom Mobile)
destination-pattern 1027.......
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
forward-digits all
I tried adding incoming calling-number to it to specifiy which callers should go out which dial-peer, but it just stopped them being able to call at all.
Hall of Fame Super Gold
direct-inward-dial
The above simply does nothing for this need. Beside, direct-inward-dial is an option for inbound pots DP, not outbound.
Cisco example configuration: is at http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
The same can also done more elegantly without number manipulation, using COR instead. There is a thread about if you look few pages back in this forum.
277
