One way audio behind NAT on 2851, is ALG running properly?
I have an IP phone behind a NAT gateway which is registering with a CM 6.1 system (which is on a public IP).
I have added ip inspect rules for the following:
ip inspect name voip rtsp timeout 5
ip inspect name voip skinny
ip inspect name voip h323
ip inspect name voip h323callsigalt
ip inspect name voip sqlnet
ip inspect name voip streamworks
ip inspect name voip tftp
ip inspect name voip tcp
ip inspect name voip udp
ip inspect name voip vdolive
ip inspect name voip icmp
I have added ip inspect rules for both in and out.
Do I need to add an ACL somewhere to force the traffic via the ALG rules as I am permitting all traffic currently to the NAT'd IP range.
I see the following during a call:
Established Sessions
Session 494A176C (192.168.192.157:49783)=>(callmanager2:2000) skinny SIS_OPEN
Session 494A1A3C (192.168.192.157:52572)=>(callmanager1:2000) skinny SIS_OPEN
Session 494A03BC (192.168.192.157:23068)=>(voip-gateway-3845:19484) skinny-RTP-data
SIS_OPEN
Pre-generated Sessions
Pre-gen session 494A149C voip-gateway-3845[1024:65535]=>192.168.192.157[23068:23068] skinny-RTP-data
However I cannot get audio in to the phone however out works fine.
I have tried a 'no nat service rtsp' however I get the following error: "NAT: Can't get system defined port"
Is there something I am missing?
thanks!
1 REPLY
Silver
Re: One way audio behind NAT on 2851, is ALG running properly?
Looks like you are using NBAR and NBAR will not let you remove the default port.
367
