One way audio issue.
Hi Guys,
I am currently studying for my ccnp voice and I have my Voice Lab set up at home. I have a SIP account that I use for outbound and inbound calls.
I have all my dial plan configured and I am doing H.323. All my outgoing calls work fine. I can make local, long distance and international calls  and I am able to hear them very well ( two way audio work fine). In the other hand when I receive a call from PSTN network no ringtone, no audio and call goes to voicemail.
I am able to see the calling number on my cisco ip phone but that is all. I did a lot of troubleshooting but no success.
Anyone can advice? Thanks
Can you post your incoming dial-peers configuration and any relevent configuration in CUCM related to your issue?
Re: One way audio issue.
These are outgoing and incoming dial-peers:
dial-peer voice 10000 voip
description Ways to 1XXX
translation-profile outgoing PSTN_in
destination-pattern 1...
progress_ind setup enable 3
progress_ind alert enable 8
session target ipv4:172.16.2.10
codec g711ulaw
dial-peer voice 10001 voip
description call to PSTN network
translation-profile outgoing PSTN_out
destination-pattern 1[2-9]..[2-9]......
voice-class codec 1
session protocol sipv2
session target dns:callcentric.com
dtmf-relay sip-notify rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
2651xm#sh run
Building configuration...
Current configuration : 10465 bytes
! No configuration change since last restart
! NVRAM config last updated at 14:56:39 GEORGIA Sun Mar 10 2013
version 12.4
service password-encryption
hostname 2651xm
boot-start-marker
boot-end-marker
enable secret 5 $1$S8u/$Y.8p.9aQGha2bZcVxPKtp/
no aaa new-model
resource policy
clock timezone GEORGIA -5
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.2.1 172.16.2.10
ip dhcp pool VOICE
network 172.16.2.0 255.255.255.0
dns-server 4.2.2.2
option 150 ip 172.16.2.10
default-router 172.16.2.1
no ip domain lookup
ip name-server 4.2.2.2
ip ssh version 2
voice call send-alert
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 700 min 60
localhost dns:callcentric.com
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 100
rule 1 /^1777282\(....\)/ /\1/
voice translation-rule 105
rule 1 /.*/ /17772821359/
voice translation-profile PSTN_in
translate called 100
voice translation-profile PSTN_out
translate calling 105
Hall of Fame Super Gold
One-way audio is generally a routing or NAT issue.
Is your call server in the same subnet as your phone?  What call server are you using?
Can you confirm with your SIP provider that you need to enable NAT?
Yes. My call server and ip phones are in the same subnet. I am using cisco MCS 7815.
Actually I am using PAT: here is the config
ip nat inside source list 1 interface fa0/0 overload
int fa0/0 is the port connected to my modem
435
