one way audio on IP to PSTN
New setup, everything seems to checkout fine, except for this:
Caller from PSTN to IP phone.
Audio both ways
IP on PSTN with remote caller
Audio one way. (remote side cant hear me)
One the LAN side, IP to IP phone works fine, No audio problems.'
So I know my problem is between the voice gateway and IP phone.
Phones are on 192.168.2.1 VLAN 100
Data is on 192.168.1.2 VLAN 200
Switchports are configured to Auto everywhere. (between phones, VG and Switch)
On the phone, I dont see any jitters, drop ped packets, etc. (hitting ??)
IP Phone:
192.168.2.12
255.255.255.0
gw 192.168.2.1 (VLAN 100 on switch)
VG
192.168.1.15
255.255.255.0
Default route 0.0.0.0 0.0.0.0 192.168.1.2
switch:
no default route sets
VLAN200 192.168.1.2
VLAN100 192.168.2.1
I ping:
from VG to IP phone (192.168.1.15 to 192.168.2.12)
From switch to IP phone (192.168.1.2 to 192.168.2.12)
From VG to VLAN100 (192.168.1.15 to 192.168.2.1)
The only thing odd I see is that when I do an extended ping to the IP phone from the switch OR the VG, i get 16 percent loss in data. Basically 84/100 sucessful pings.
Any hints?
Thanks!
Hall of Fame Super Gold
Re: one way audio on IP to PSTN
Worry not, the phones by design doesn't reply all the pings.
What is the VG and what SW do you have on it. Also what FW on the phone and if you are using CCM which version and which protocol to the VG.
12.2(25)SEE3 switch 3460
VG 12.4
CCM 5.1
Protcol NI2 (global) at VG
phone load 41.8-2-2sr2s
248
