One way audio over VPN (Except for CIPC)
Hi all,
We are facing a one way audio problem using Cisco 6961 over a VPN tunnel.
Not NAT is used. The ipphones on the remote site can't hear the users from the HQ where the CUCM is deployed.
The stange thing is is working fine when we use IP Communicator softphone instead of the hard ip phones.
Both (CIPC and 6961) are in the same subnet .
Any idea is welcome.
Thank you in advance
FYI we are using gateprotect firewalls on both sides of the tunnel and all tcp/udp ports open.
I would look into getting Wireshark captures of each side of the conversation during an CIPC call and then for a 6961.  Look for any differences between the captures.
Thank you brian. I really appreciate!
I believe you are having two vlans for voice and data. Your desk phones are in voice vlan. CIPC will use data vlan.
If this is correct, then below are some points:
1. Make sure that your voice VLAN subnet is part of your VPN interesting traffic.
2. From your desk phone's default gateway (which is probably a router) initiate a ping to any remote phone. Use the source interface as your phone's default gateway. For example:
ping ##remote phone IP### source ###Phone's default gateway###
Hi mohamme
Thanks for your answer. I have only one vlan for voice and data. Both pc and ipphone are on the same subnet.
Re: One way audio over VPN (Except for CIPC)
- Try to ping your 6961 phones from your gateway route.
- I am assuming that both sites are registered to same cucm. What codec is configured.
- Trust point relay is enabled or disabled on phones.
Hi Mohammed,
-Ping is sucessful from the HQ to the 6961(remote site).
-Both sites are registered to the same cucm .For test, same region , device pool codec is configured for both sites.
-No trust point relay is configured .
Best regards
Hi all:I have one way audio
Hi all:
I have one way audio on a vpn connection between remote officers and my central cisco ASA , in a fourum we found that the following line can be the problem on the 5500:
policy-map global_policy
 class inspection_default <<<<<<<<<<<<<<< removing this line
  inspect h323 h225
  inspect h323 ras
What do you think about?
JON
593
