one way audio vg224
Tommer Catlin
Anyone remember what the command is that fixes one way audio on vg224?   I already have no ip routing turned on and I still get one way audio between VG224 port and IP phone on the same switch, etc.  I know its not network related and I had this problem before somewhere.  Just cant recall what command goes in the vg224 to fix this.
5 Replies 5
paolo bevilacqua
reload ?
actually I had to remove no ip routing
so turned ip routing on I guess and it worked fine.
This worked for me also. Had one-way audio and ip routing fixed this.
Worked for me too.
Kevin Monteiro
Level 7
Level 7
Hi Tommer,
Have you tried checking the cabling, i mean the patch panel?
Kindly rate the post accordingly.
Kevin
