12-27-2011 08:53 AM - edited 03-16-2019 08:42 AM
We have changed IP addressing of our VoIP phones from Public Range to Private 10.x.x.x. Our Main Site IP addresses change took place before I started so don't know if some configuration change was made on CUCM 6.1.3 to make it work. I changed the IP addressing of Voip Phones on one of the Remote site connected to main site (where Publisher / Subscriber resides). At the remote site I enabled the DHCP scope to allocate IP addresses to IP phones. I created the voice vlan and configured the correct voice vlan to switchport IP phone is connected. Phone gets the IP from DHCP scope and also gets correct parameters such as gateway,option 150 etc. Phone gets registered to Subscriber call manager. I have checked the IP cache and I see the session to port 2000.When
I call from our main site to phone assigned to new VLAN ,Remote site phone can hear us but we can't hear them and issue remains the same when call is initiated from remote site to phone's on other VLAN's or sites.
At remote site I installed another phone and assisgned the switchport to new voice vlan then both new phones can communicate to each other but same issue in communication to phones on other vlans / locations
I have checked all the access-lists and FWSM but couldn't see any issues ....ANY IDEA what's causing one way communication issue cos previous team changed the IP addresses on our main site but no such one way communication issue. Interesting thing is that I picked one of the free subnet from Main site IP address planning structure and implemented at remote site and had no issues with communication at all
thanks
Mukesh
12-27-2011 09:02 AM
Hi Mukesh.
From your remote site, try to ping a phone of Main Site from the remote site voice vlan subnet.
Try in and let me know..
Carlo
12-27-2011 10:26 AM
Mukesh,
One way voice 99% of the time indicates routing issues, make sure your new VLAN subnet is properly advertised throughout your network and reachable from the main site. "sh ip route" at the main site should show that route as available and pointing to proper destination.
HTH,
Chris
12-27-2011 11:16 PM
Hello Chris,
C 109.205.117.228/30 is directly connected, GigabitEthernet0/3.522 this subnet is advertised in my router
My configuration are:-
On Router
interface GigabitEthernet0/3.522
encapsulation dot1Q 522
ip address 109.205.117.229 255.255.255.252
On switch
interface fa0/11
switchport voice vlan 522
switchport mode access
switchport port-fast
CUCM :
Ip add:- 109.205.117.230
If you found any wrong in this configuration please tell me .
Mukesh
12-27-2011 11:40 PM
Hi Mukesh,
Am I right that your CUCM is connected to interface fa0/11? Then remove command "switchport voice vlan 522" and replace it with simple "switchport access vlan 522"
12-27-2011 11:42 PM
Hi Mukesh.
The routing problem, is not between ip phones and CUCM but between Remote and main site IP phones subnets.
Keep in mind that rtp flows dorectly between ip phones.
So you have to check rechability of ip phone subent of main site from ip phone subent of remote site.
Are you able to ping from remote site the main site subnet assigned to ip phones?
Let us now.
Carlo
12-28-2011 03:30 AM
Hello CARLO,
you are right my routing is good because i can ping my CUCM ip from ant network and CUCM also.
But i want know that i assign the DHCP Subnet 10.10.0.0/16 but when i saw the IP Phone ip address then IP Phone have ip of its own network what it that problem or not ?
Cau please explain about the IP Phone subnet?
Mukesh
