Community Member
One way dialing
On CallManager 5.0(4) I installed a new 7941G as a SCCP Phone. It worked but calls to it's extension failed "You call can not be completed as dialed. Please consult your directory..." Calls from the phone work.
Ideas?
Jim
Hall of Fame Super Silver
Re: One way dialing
Seems like a partiton/calling search space issue.
Chris
Community Member
Re: One way dialing
check the CSS name applied on your device, then check which partitions are added under that CSS, then check which route patterns are under those partitions included in your Phone CSS.
Pl. rate the post
Community Member
Re: One way dialing
Rebooted CallManager 5.0 and the problem went away.
163
