One Way SIP Audio after Route-List Hunting
Hello All,
I was wondering if anyone has every had this issue and what might be the cause. I have 2 analog circuits setup for 911 and local calling on a 2821 router. The local calling is only for testing in this case.
I have set my cell number as a route pattern and directed it to a route-list which first includes this 2851(to pots lines) and then a cisco CUBE with a SIP trunk.
What happens is when I pull out the analog ports on the 2851 and I try to make a call to my cell from a cisco phone the call completes but I only get one way audio. They can hear me on my cell but I can't hear from them(ip phone). When I unplug the 2851 from the network the call completes and there is two way audio. I think the issue here is the 2851 because everything works when it is out of the picture. I'am running code c2800nm-spservicesk9-mz.124-20.T2.bin.
Here are my Dial Peers
dial-peer voice 1003 pots
preference 2
destination-pattern 1T
direct-inward-dial
port 0/0/0
prefix 61
dial-peer voice 1001 pots
huntstop
preference 4
direct-inward-dial
port 0/0/1
prefix 61
please ignore the prefix
1 REPLY
Re: One Way SIP Audio after Route-List Hunting
Hello All,
I have resolved the issue by changed the enable fast start codec to g729AnnexB and issues a reset. Why migh this have fixed it.
124
