One Way Voice: Cisco 2801 <-> Elastix (Asterisk)
Hello All.
I'm facing a one way voice problem between a Cisco 2801 and Elastix.
I just configuring a dial-peer pointing the traffic from PSTN.
Caller from PSTN side can hears the Called from VOIP side.
The topology is
PSTN <--> voice gateway   <--> Elastix
Gleidson
Green
One way transmission is caused by IP routing
issues
From your gateway IP address 189.84.48.10
can you ping an actual IP phone that you are
trying to call.
Alex
Regards, Alex. Please rate useful posts.
Yes, I can Ping.
I used the debug voip RTP and I saw that the rtp packets are sent to asterisk instead of sent to the phone.
Its wrong, the destination of packet should be te machine where instaled my ip phone.
Do you know I can resolve this?
Green
Try running a
debug ccsip messag
Se if that gives a clue as to what address the pbx
requsts the rtp streams to use
Alex
622
