one way voice communication problem
We are trying to configure a sip gateway with the below configuration. The router is installed with 4 fxo ports which i am connecting to a pstn line with the config as below.
dial-peer voice 10 pots
destination pattern 9t
port 0/0/0
forward digits all
When i dial any outside number through sip soft phone ,I am facing one way voice issue.
There is no sip servers as such in the network.
Re: one way voice communication problem
Take a look at this document to troubleshoot one-way voice issue...
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
hieu
Super Bronze
Check you have 'IP routing' enabled globally.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
When you say there is not sip servers in the network, then how do you intiate the call?
Which sip softphone are you using?
At you sip phone, what do you configure for sip proxy?
I had done test before, basically you need a dial-peer voip using sipv2 point to your sip softphone
SS
187
