One way voice on E1
talha_78_2000
Our ip telephony setup was working fine from 1 year . Recently from one month it start giving problems. The External outgoing calls through E1 are sometimes one way - voice calls. We can here the voice but the other cannot here the voice. We did not change any configuration on the gateway.
we are using 2811 (C2800NM-IPVOICE-M), Version 12.4(9)T1 of IOS on voice gateway.
1. We also have 4 FXO for international dialing. if we move the local calls to FXO there is no problem.
2. Incoming calls on E1 have no problem.
3. on outgoing calls there is problem but the problem is random. sometimes the call is two-way sometime its one-way call . we suspect that some channels may be one way so we monitor the calls but one the same channel of E1 some time the call is one way sometimes its two-way.
controller E1 0/0/1
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 1 timeslots 17-31 type r2-digital r2-compelled ani
cas-custom 0
country saudiarabia use-defaults
cas-custom 1
can anyone suggest or help regarding this issue.
9 Replies 9
paolo bevilacqua
Hve you tried reloading the router ?
Is the controller clean and free of slips ?
Yep i restarted the router many times but it did not fix the problem.
The think which confusing me is the behavior of the problem its not fixed its random . we also check with the PSTN - E1 provider but they said there is not problem from there side and they have'nt make any changes on there side.
I am suspecting the problem with the E1 module. but i dont have any other E1 module to test.
Please send output of "show controllers E1" and confirm you have access to 12.4(11)XJ4 for upgrade.
Yes i have access to 12.4(11)XJ4 , i can upgrade the IOS.
Here is the output of sh controllers E1
E1 0/0/1 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060711, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (149 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
Controller is clean and I would go ahead with the upgrade. Let us know if it solves the problem.
I upgrade the IOS but it did not fix the problem. Still we have random one-way calls. After upgrade one of my E1 is not working and showing the status as BLOCKED. We have two E1 with 15 DID and 15 DOD each. I give the preference to other E1 so the calls are going through other E1.
Please check the attachment and suggest me how to fix this problem.
Please find the following link which will give you troubleshooting steps to isolate the issue...
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml#intro
Regards...
-Ashok.
With best regards...
Ashok
kbradshaw
Well.. without seeing the config i would have to guess but it sounds like you have header compression on one end of the circuit and not the other ..you either have to have it on both ends or no ends
hope this helps
K
K,
header compression ? This is a VoIP forum and the problem has nothing to do with data circuits.
Unfortunately I'm unable to suggest a possible cause and since my suggestions have not resolved the issue, I hope an alternate solution can be found.
