Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
One way Voice
I am getting one way voice but only from calls where there has been a call forward has been set
Re: One way Voice
have you revised if there is any firewall between the endpoint and tht CUCM? If there is a firewall between them it's possibly that it is blocking some ports.
If you found this post helpful, please rate it
Re: One way Voice
You should check full ip path. How packed following. Ie in my case was similar problem.
My case was following :
             ISDN Pri                             h323
Cell GW --------------- Cisco GW(3725) ---------- Softswitch --- user
And between Cisco GW and Softswitch was router wich perfom nat for packets following to softswitch and I had problems.
In your case you should carefully check out connectivity and all network elements. Most often existing problem is firewall. Is it exists in your scheem ?
468
