only manager must use one of the fxo port
hi,
2851 ccme router, 7961 ip phone for the manager
i asssigned 2 lines for the manager
one for his DID number
and the second line is his analog line(plar works under analog line)and directs the calss his ip phone second line
manager has direct line,and i added plar for outside callers can directly reach the manager if they know his direct number.. But when the manager wants to call from his direct line he can call outside from another fxo line.. is it possible to let him to call from his direct analog line not from the other fxo lines..
output of the sh run
voice-port 0/2/3
timeouts wait-release 3
connection plar opx 99
i got 2 x vic2-4fxo
Green
Re: only manager must use one of the fxo port
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611369.html#wp1094625
Yes, try to use the TRUNK command. under EPHONE-DN
Configuration sample is the link.
//G
hi
it is ok and working
but the problem is if someone from pstn calls this direct line, the callerID seen on the ephone is 801 .config is below
any idea? thanks.
voice-port 0/2/3
description analogue line
dial-peer voice 801 pots
destination-pattern 801
port 0/2/3
ephone-dn 2
number 99
pickup-group 14
label direkt hat
name test
hold-alert 30 originator
trunk 801 timeout 10
ephone 39
ephone-template 1
username manager
type 7960
button 1:73 2:2
Hall of Fame Super Gold
You see 801 because that is the tagnumber of DP and caller-id is not enabled on that line.
If you do not have caller-id, configure a tagnumber that you like as DP.
or else, configure station number under voice port. This will overwrite if no caller-id info is received.
ok i changed little bit the config
voice-port 0/2/3
description analog line
caller-id enable
ephone-dn 2
number 99
pickup-group 14
label direkt hat
name test
port 0/2/3
ephone 39
ephone-template 1
mac-address 0018.BAF8.B9FE
type 7960
button 1:73 2:2
analog calls come and i can call from my analogue line
but still callerID is missing.
any idea?
thanks
Gokhan
Hi, please configure "cptone " under voice-port to enable caller-in the router.
As a courtesy to those providing answers, please rate all useful posts using the scrollbox below!
118
