Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
only one agent not getting calls only for one Skill
                   Hi ,
I'm using UCCX 8.5 with call manager 8.5.
My problem is in one application one agent called 'X' is assigned 2 skills 'A,B' and put in into CSQ 'Y'. in this CSQ there are 3 agents.
only agent X is not receiving calls only for skill B.she is receiving for Skill A. other 2 agents are receiving calls for Skill A ,B.
I cross checked the configuration. itis fine. CSQ shows agents as all 3.
please help to troubleshoot the problem
Move your post to the Contact Center section and you will have a better chance for your question to be answered.
Hi.
Are you selecting agent by resource group or skill level?
If you leave only agent X, what happens to a call hitting the CSQ?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
I'm selecting resource by Skills.
Now I'm testing with Resource group and leaving only one agent and update you the result.
Thanks for your response
Hi, I tested by selecting the resource by resource group it didn;t work only for this agent.i tested by putting only this resource and tested. it plays agent busy prompt even this agent is ready.
any other suggestion to test.
166
