Only one DiD number works and secondary ephone-dn are valid
I have a strange problem that is driving me nuts. I have a new test CME system Version 4.1(0) with a VIC2-2BRI-NT/TE ISDN card with two active spids. sh isdn status shows no ISDN trouble I am trying to set up DiD and have the following dial peer
dial-peer voice 20 pots
incoming called-number .
direct-inward-dial
port 0/0/0
interface BRI0/0/0
no ip address
isdn switch-type basic-ni
isdn point-to-point-setup
isdn spid1 97048484671111
isdn spid2 97048486741111
isdn incoming-voice voice
isdn supp-service name calling
end
and I have the following ephone-dn configured
ephone-dn 1 dual-line
number 2201 secondary 4848467
ephone-dn 2 dual-line
number 2202 secondary 4848674
Calls back and forth from all numbers inside the network work well. Calls from the PSTN to 9704848467 OR 4848467 route to ephone-dn without problem
Calls from the PSTN to either 9704848674 or 4848674 connect just fine (IAW debug isdn q931) however, I get the network message ?the line is busy?
Anyone have any ideas as to why ISDN connects, but I get the busy message for anything but the first SPID. BTW I have tried this with and without the area code and get the same result. I also have some non spid numbers that also ring through on the debug messages and get the same result. (They are tied to another ephone-dn) I have checked and triple checked to make sure I do not have a typo, incoming messages are tied to a ephone-dn.
Is their a voice debug command I should try?.
debug isdn q931
Oct 2 19:15:17.174 MDT: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x32
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x88
Exclusive, No B-channel
Signal i = 0x40 - Alerting on - pattern 0
ENDPOINT IDent i = 0x818B
Calling Party Number i = 0x2183, '9706919064'
Plan:ISDN, Type:National
Locking Shift to Codeset 5
Codeset 5 IE 0x2A i = 0x809403, ' a=', 0x9E05, 'From ', 0x8B0C, '970 691-9064', 0x8001019E03, 'to ', 0x830C, '970 484-8674', 0x8001048001, '('
Locking Shift to Codeset 6
Codeset 6 IE 0x7B i = 0x81
CME-2801#
Oct 2 19:15:17.186 MDT: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xB2
Channel ID i = 0x89
Exclusive, B1
Oct 2 19:15:17.206 MDT: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xB2
Cause i = 0x8090 - Normal call clearing
Oct 2 19:15:17.254 MDT: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x32
Signal i = 0x4F - Alerting off
Codeset 5 IE 0x2A i = 0x808001, 'P'
Oct 2 19:15:17.258 MDT: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB2
1 REPLY
Re: Only one DiD number works and secondary ephone-dn are valid
debug voip ccapi seems to show that the destination number is include in the successful trace but not included in the unsuccessful trace yes the debug isdn q931 messages show a "to" number.
Is this a feature that my carrier needs to turn on for the other numbers?
! Successful
----- ccCallInfo IE subfields -----
cisco-ani=9706919064
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=4848467
cisco-desttype=4
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
! Unsuccessful
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
315
