only send 4 digits to PSTN
When I place a call to PSTM throught a BRI port, in a CME 8 the telephone try to place that call sending only 4 digits, when I am introducing the digits, in the 4º digits stop and try to send the call.
Progress Ind i = 0x8183 - Origination address is non-ISDN
      Calling Party Number i = 0x0080, '4110'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '630'
        Sending Complete
Jul 18 13:20:52.155: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xC4
        Channel ID i = 0x89
                Exclusive, B1
Jul 18 13:20:52.175: ISDN BR0/0/0 Q931: RX <- PROGRESS pd = 8  callref = 0xC4
        Cause i = 0x829F - Normal, unspecified
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
        Progress Ind i = 0x8A88 - In-band info or appropriate now available
Jul 18 13:20:56.139: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x44
I have checked interdigits timeout, and it is set to 5, dial-peer are correctly configurated
RouterVallecas#sh dialplan number 0630112233
Macro Exp.: 0630112233
VoiceEncapPeer210
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `Moviles',
        tag = 210, destination-pattern = `06........',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=1,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 210, Admin state is up, Operation state is up,
        Outbound state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
dial-peer voice 210 pots
description Moviles
preference 1
destination-pattern 06........
port 0/0/0
forward-digits 9
If I try to place a call to other number always is the same result, 091....... only place 4 digits, and so on.
Any idea where could be the problem?
Thanks!!
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: only send 4 digits to PSTN
There is another dial-peer then.
try 'show dialplan number 0611 timeout'
Hi Ivan
Please show the whole configuration. Might be, that you are matching a translation rule.
Cheers
Peter
Hi!
I just found the problem, i had a dial-peer voice with destinattion-pattern ´....´ , when i removed it, all right.
thanks everybody,
regards!!!
You're welcome, please remember to rate useful posts clicking on the stars below.
311
