Community Member
Onnet Calls Connected Party information
Hi all,
had a problem with the "connected party" display when Onnet calls is make between two Phones in two CCM clusters via a H323 Gateway.
Can we modified the manipulated "connected party" information(no restricting) to tell the caller party that they are dialing the right number?
I am not modifying any calling party or called party information just the connected party information
1 REPLY
Community Member
Re: Onnet Calls Connected Party information
Try the same with MGCP Gatway it will work fine, h323 gateway with in the cluster you can get Connected Party information.
131
