Optimal Unity Custom Prompt Audio Settings G711
Does anyone know what the optimal audio foramt is for a G711 Unity Audio Prompt Wav file?
Re: Optimal Unity Custom Prompt Audio Settings G711
Well the simplest way to find out is .. right click an existing call handler prompt file in unity and check the file properties.
Deepaqup,
Average Data Rate 8.0 kb/second
Sample Rate 8.0 Khz
Audi Sample Size 8.0 Bit
Channels 1 (Mono)
So this is the Optimal quality for a G711ulaw Prompt?
You are right.
If the sample rate is 8.0 Khz and also if sample size is 8 bit then the Data Rate will autimatically be 64Kbps
Every thing else is fine :)
112
