Community Member
Originating Calling Number for CUE
Hi all,
Let me explain my issue.
Here is a ephone-dn configuration on my CME:
ephone-dn 52
number 49
description JD
name JD
call-forward all 20
hold-alert 30 originator
So If someone (from PSTN) is calling the 00352XXXXXX49, the call is redirected to the extension 20 (due to CFWALL), and then the 20 get the call, it shows on the screen the Original Calling number (PSTN) and the first called number and name (49 and JD) also.
So, this is working fine. Now we just added a CUE to redirect all call through a Welcome message (AA from CUE) and then transfer the call to extension 20. So if someone call extension 49 from PSTN, it will go to extension (99 ==> AA), play a prompt, and then transfer to 20.
Here is now my ephone-dn
ephone-dn 52
number 49
description JD
name JD
call-forward all 99
Here is the problem. When 20 is ringing, it only shows the PSTN Number (orginating calling number). And I'd like that all parameter like before could be shown on the screen.
If someone has an idea...
Thx u for this.
Silver
Re: Originating Calling Number for CUE
Check whether calling-number local" which is issued under telephony-service that would cause calls that are forwarded to show the forwarding phone's number not the originating sides.
Community Member
It doesn't change anything...
here is my Telephony-service configuration:
CME_2811#sh telephony-service
CONFIG (Version=4.0(3))
Version 4.0(3)
Cisco Unified CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 192.168.0.254 port 2000
load ata ATA030100SCCP040211A.zup
load 7920 cmterm_7920.4.0-02-00
load 7936 cmterm_7936.3-3-5-0
load 7970 TERM70.7-0-3-0S
load 7914 P0030702T023
load 7960-7940 P0030702T023
max-ephones 40
max-dn 144
max-conferences 4 gain -6
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
voicemail 89
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] FR (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] FR (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
mwi relay
moh music-on-hold.au
time-format 24
date-format dd-mm-yy
timezone 0 Greenwich Standard Time
secondary-dialtone 0
no call-forward pattern is configured.
transfer-pattern 0T
transfer-pattern ..
keepalive 30
timeout interdigit 5
timeout busy 10
timeout ringing 180
caller-id name-only: enable
system message xxxxxx
web admin system name admin password xxxxxxx
web admin customer name cusadmin password xxxxxxx
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp Jan 01 2002 00:00:00
transfer-system full-consult
local directory service: enabled.
testing xml apis
Extension-assigner tag-type ephone-tag.
Thx for your help
Fabian
187
