Community Member
Orphaned Call Leg
Hi All,
I've got a Cisco2801 with a call leg that is holding open a channel and causing some calls to be dropped (because the router tries to assign that channel to a call)
RT_Nelson#sh call leg ac sum
G<id> L<id> Elog A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp>
GAE4 L 13714 N ANS T0 None TELE P35486918
Total call-legs: 1
Its been there for 3 days now, we have unplugged the PRA and had the telco reset it from their end. Is there a way to kill this call leg other than recycling the router entirely?
Community Member
Re: Orphaned Call Leg
Here is the debug for the rejected call:
Aug 28 2009 15:58:50.967 NZST: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x01FA
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18382
Preferred, Channel 2
Date/Time i = 0x09081C0F3A
Signal i = 0x40 - Alerting on - pattern 0
Calling Party Number i = 0x2181, '44961865'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '5399009'
Plan:Unknown, Type:Unknown
Aug 28 2009 15:58:50.975 NZST: ISDN Se0/3/0:15 **ERROR**: cdapi_process_connect_resp: cdapi
sez to reject the call (appl rejected?)
Aug 28 2009 15:58:50.979 NZST: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x
81FA
Cause i = 0x80AF - Resource unavailable, unspecified
Hall of Fame Super Gold
These are typical IOS bug, only solution is to reload the router.
Community Member
Thanks. I was hoping there was another way. Do you know if its been resolved in any IOS's?
Not sure, this kind of stuff comes and go, once you find a stable image better stick to it.
Please remember to rate useful posts with the scrollbox below.
179
