Orphaned RTP sessions
We have enough resources ont he CISCO2811 router for transcoding. We have resources available to handle 30 calls but it does not take more then 16 calls.
The issue of not taking more then 16 calls is now a challenge. Here is the output of the ' sh voip rtp connec'
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP LocalIP                                RemoteIP
1   26797      -1            17104    0         64.32.44.23                          0.0.0.0
2   26807      26808      17620    6148   64.32.44.23                          215.230.56.90
3   26808      26807      19294    23078  10.50.1.42                             215.230.23.3
4   26809      26810      17366    2000   10.50.1.42                             10.50.1.42
5   26811      26810      19370    2000   10.50.1.42                             10.50.1.42
6   26812      -1             18266    0          64.32.44.23                          0.0.0.0
7   26813      26812      17712    23218  10.50.1.42                             215.230.23.3
8   26814      26815      18506    2000   10.50.1.42                             10.50.1.42
9   26816      26815      17722    2000   10.50.1.42                             10.50.1.42
10  26842      26843      19088    29478  64.32.44.23                          83.166.173.32
11  26843      26842      19008    18572  10.50.1.42                             215.230.23.3
12  26844      26845      17034    2000   10.50.1.42                             10.50.1.42
13  26846      26845      17046    2000   10.50.1.42                             10.50.1.42
14  26872      -1             19016    0          64.32.44.23                          0.0.0.0
15  26873      26872      17360    18468  10.50.1.42                             215.230.23.3
16  26874      26875      17696    2000   10.50.1.42                             10.50.1.42
17  26876      26875      16852    2000   10.50.1.42                             10.50.1.42
18  26897      -1             18514    0         64.32.44.23                          0.0.0.0
19  26898      26897      16940    18152  10.50.1.42                             215.230.23.3
20  26899      26900      18310    2000   10.50.1.42                             10.50.1.42
I see that there are some of the calls with callID as "-1" and no destination port number or ip address. I believe that these are the RTP sessions that are failing. Any guess about the cause of this?
saif
Hall of Fame Super Silver
Re: Orphaned RTP sessions
each call uses 2 transcoding resources one for each call leg, so if you have 30 sessions configured only 15 calls will use it. Can you post your config?
Chris
Well that does not sound correct. I had configured 16 sessions on dspfarm profile and I could see that 16 calls were transcoded without any problems. Now when I increased the resources and configured 32 channels, only 16 calls are getting through.
Moreover, this is not an issue with transcoder bcoz I can see that transcoding is taking place for all 32 calls but just the RTP is not correctly being established. Its evident that no RTP would succeed without proper destination IP Address and port.
Could someone please tell me what exactly dstCallId "-1" means?
Saif
198
