Community Member
OS.2003.1.1 on HP DL320-G2 supported?
I am trying to install UCCX7 on one of my lab servers, which is a HP DL320 G2. This server is the hardware equivalent of the MCS-7825H-2266, which is supporting OS.2003.1.1. The only thing i have changed in the HW-configuration is that i replaced the original 40GB-HDD with an 120GB-HDD, as the installation wizard stated, that the 40GB is not supported, i need a 72,6 GB-HDD. But now the wizard says the 120GB is also not supported, i need the 72,6 GB one.
CUCM 6.x is working fine on this server with the 120GB-drive. Why isn't the OS-2003.1.1 working? I don't think that a 72,6GB IDE-HDD is currently existing.
Re: OS.2003.1.1 on HP DL320-G2 supported?
This Cisco Unified Communications operating system requires a minimum of 72 GB of disk space on MCS-7835 and MCS-7845 servers and requires 80 GB of disk space on the MCS-7815 and MCS 7825 servers with SATA. If the installation process detects less than required disk space on the server, the installation aborts.
Community Member
But in my case the installation process detects more space than required and aborts the installation.
The DL320G2 supports only IDE-HDD and no SATAs.
