OS administrator login failure after upgrade from 4.2 to 6.1
i upgraded my CCM cluster (Pub & Sub) from 4.2 to 6.1 through DMA.
All is working fine, and my new cluster is operative.
the only problem i meet is that i'm not able to login as "OS administrator" into the subscriber. But i can login properly into the pubblisher.
No problem with CM administrator's username/password for both publisher and subscriber.
There is a way in order to reset username/password for OS administrator??
thanks for any help you can provide me
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: OS administrator login failure after upgrade from 4.2 to 6.1
Hi there,
Have you tried the username "administrator" without the "OS"
Also check out this great thread from Michael @ Cisco;
https://supportforums.cisco.com/message/1122362#1122362
Cheers!
Rob
utils reset_ui_administrator_name
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_1_1/cucos/iptpappa.html#wp1120161
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi there,
Cheers!
Rob
java
java
237
