Community Member
OS Installation on MCS-7825-H3
We have a new 7825-H3, with CCM 4.2 disks. This comes with OS 2000.4.3(a). This fails to load the OS onto the server. Compatibility matrix shows OS 2000.4.4 minimum for a 7825-H3. How can we get a 2000.4.4 CD or download from TAC?
Re: OS Installation on MCS-7825-H3
you'll need to use the PUT to get the media, OS installs are not available for download, only upgrades are available.
don't mind opening a TAC, they'll tell you exactly the same
http://tools.cisco.com/gct/Upgrade/jsp/index.jsp
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Thomas,
We are running into the same exact issue. can you tell me how you resolved this?
187
