OS User name in CUCM
I have created a OS user in cucm and it is not reflected to subscriber, is this a normal condition or abnormal,
Please reply
1 ACCEPTED SOLUTION
This is normal.  You must
This is normal.  You must create local platform accounts on each server separately.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
VIP Purple
Hi Jack, It should show in
Hi Jack,
It should show in all servers in a cluster.
OS user gets created while building/installing the Call Manager.
what is CUCM version u are using?Did u try logging into OS through CLI of Pub and Sub.
also,check DBreplication by running command utils dbreplication runtimestate
regds,
aman
Dear Aman,The OS user which
Dear Aman,
The OS user which was created while installing that is working fine After installing when i logged in i created additonal OS user in publisher that is not reflecting in subscriber, because i am not able to login in subcriber by the newly created OS user. I am using CUCM 9.1
Is it normal or it shld replicate also??
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
DB CLI Status: No other dbreplication CLI is running...
Cluster Replication State: BROADCAST SYNC Completed on 1 servers at: 2014-03-11-        20-18
     Last Sync Result: SYNC COMPLETED  603 tables sync'ed out of 603
     Sync Errors: NO ERRORS
DB Version: ccm9_1_2_11900_12
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from CUCMPUB01DC (2 Servers):
                                PING            CDR Server      REPL.   DBver& R        EPL.    REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    (ID) & STATUS   QUEUE   TABLES L        OOP?    (RTMT) & details
CUCMPUB01DC    10.1.15.11      0.076   Yes     (2)  Connected   0      match   Yes     (2) PUB Setup Completed
CUCMSUB01DC    10.1.15.12      0.982   Yes     (5)  Connected   0      match   Yes     (2) Setup Completed
VIP Purple
Hi Samuel, What I have
Hi Samuel,
What I have understood is that while installing PUB and SUB , u have sucessfully created OS /Platform user and u are able to login with these credentials in CLI/OS GUI into both servers.?
Now , u created one more OS user in Publisher and u want to login with these credentials in Subscriber.I doubt this would happen since with the new user, u would be able to enter into CLI/OS GUI of Pub only.
Have u used set account name [USERNAME] in Pub while creating new user?
regds,
aman
Hello Aman,What I have
Hello Aman,
yes
So i shld understand this is normal with every CUCM
yes
Anthony Holloway
 Thanks Anthony and aman for
Thanks Anthony and aman for the reply
For the confirmation of OS user are individual in publisher and subsriber.
VIP Purple
Hi Samuel, yes, that is
Hi Samuel,
yes, that is created only for each server separately.
regds,
aman
163
