Oub & Subs different MCS's
hi
for a callmanager cluster is it possible to have different series MCS's for publisher and subscribers, for example to have 7825 publisher and 7835 or 7815 subscriber and so on..
thanks
Hall of Fame Super Red
Re: Oub & Subs different MCS's
Hi U-C,
There is no requirement that the Pub/Sub MCS servers be identical. As long as they support the version of CCM that you are building you should be good to go! The consideration that comes into play here is when thinking of "failover" scenarios. You don't want a server that only supports x number of phones to be less than what you need in case of failover.
Other than that there are no issues :)
Hope this helps!
Rob
what about if different versions, i mean pub of 5.x while sub is 4.x
i think this is not possible
but just to make sure?
Hi U-C,
You are most correct here, the CCM versions must be exact :) A 4.1.3 Publisher CCM will not work with a different Subscriber version (like 5.x or vice-versa). I'm sorry I misunderstood your original question.
Hope this helps!
Rob
Silver
user-cisco,
Well this is possible. Take for example what would occur if you were to perform an upgrade on a cluster?
Essentially, you would perform the upgrade on one of the members of the cluster first before moving onto the next. After this initial upgrade - you will have a cluster running disparate versions of CCM. Of course leaving this as-is will not be recommended. So as you know the best practice is to have all members of the cluster using the exact same version of code including any patch updates.
hth
Ajaz
thanks Rob, Ajaz
245
