Out of Memory in Server.
Hi guys,
I found an error in my publisher server"“Out of Memory: Killed process 12823” so I can not login the server through CLI or web interface,After done hard reset, the server has came up and running fine.I believed that it is due to internal memory issue in linux.Could guide me to fix this issue .
AZ
1 REPLY
Re: Out of Memory in Server.
To check if there are any performance issues on the Publisher you can check the outputs of the following:
show status  ( to check for disk / memory / cpu usage )
utils diagnose test ( to test disks, raid, network, ntp, tomcat etc )
utils core active list ( to check for any core dumps due to memory starvation or lack of cpu resources etc )
If you find everything normal in these outputs and you are still interested in RCA for the issue then you will need the detailed ccm traces , RisDC perfmon logs to begin with for the timestamp when the issue was reported.
Manish
97
