Out side clals not goin through
we are facing teh problem with the outside calls all internal calls are working well but if we dial outside calls its not working.
i am attaching the show voice call status details with this . kindly help me to fix this isue. how we can know if there is any problem in the minsitry side .
all e1's and interfaces are showing up.
kindly help me to fix thsi issue.
regards
sunny
Re: Out side clals not goin through
Try to reset the signaling protocol.
Router # no mgcp
Router # mgcp
i done the command still we are facing teh same problem kindly give you suggestions
Please upload a CCM detailed trace with matching debug isdn q931, include the calling party number and called party number.
//J
we are using the e1 and teh signaling is R2 Signaling kindly help me to fix this issue.
122
