Outbound and Inbound Dial peers
Hello everyone!
How can I match an outbound call to a dial peer. For example I need internal number 1000 to go through dial-peer 1 and internal number 1001 to go out through dial peer 2?
And another question regarding inbound calls
How can I make an inbound call to 4040404 to go to internal number 1001 and another call to 4040405 to go to internal number 1002? Should I use translation rules or there is any another command under dial peer to match an inbound call to an internal number?
Thank you!
Everyone's tags (5)
1 ACCEPTED SOLUTION
VIP Super Bronze
SInce this is CCME, you will need to use voice xlation rules to modify the called number and apply it to the ephone-dns..
1. To select dial-peer 1 to use for outbound calls on dn 1001 and dp2 for 1002, you should modify the called number on both dn as follows
if called number= 5000
voice translation-rule 1
rule 1 /^5000/ /775000/
voice translation-profile ext1001
translate called 1
voice translation-rule 2
rule 1 /^5000/ /885000/
voice translation-profile ext1002
translate called 2
Then create dial-peers to macth the xlated numbers
eg. dial-peer voice 1 pots
destination-pattern 77T
port x/y/z:15
dial-peer voice 2 pots
destination-pattern 88T
port a/b/c:15
finally apply the xlation rule to either the phones or the dn
ephone-dn 1
number 1001
translation profilce incoming ext1001
ephone-dn 2
number 1002
translation profile incoming ext1002
This way the dial-peer used will depend on the extension that is calling
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
You can use answer adress command under the dial-peer to match the call to that dial-peer
Yes you should use voice translation rules for map 4040404 to whatever number you want to
Is it true for POTS dial peers as well? I forgot to mention that it is a CME setup with E1, so should I use voip dial peers or pots dial peers for inbound and outbound calls?
VIP Super Bronze
translate called 1
translate called 2
port x/y/z:15
port a/b/c:15
ephone-dn 1
number 1001
ephone-dn 2
number 1002
Ok, if the called number 5000 is known, then I agree. But what if the called number is .T, in another words ANY called number?
VIP Super Bronze
Then get creative! Its that simple. You should be familiar with the dial plan of your environment. These are PSTN calls and they usually start with a pattern eg. 9 something or 0 something..Most users either dial a 9 or a 0 as the start of their dialling.
Adjust the config to match the dialled pattern. The key is to prefix a number to the dialled pattern so that you can use a specific dial-peer as you want
In other words it is not achievable with POTS dial peer and answer-address configured?
Can I use this kind of translation for ALL calls?
rule 1 // //
VIP Super Bronze
And do you know what this does? What do you want to achieve by using this. Why dont you want to use my painfully thought out suggestions above?
I though it would just translate the called number to itself, in other words, it will not translate it at all, but there will be a corresponding translation profile to associate with a dial peer
Haha, Your solution is painfull indeed, I just want to simplify it if possible
VIP Super Bronze
I like your sense of humour. But I am sorry to say that I dont see how that xlation rule will help you. You can try it. There is nothing overly complicated about using the idea I suggested.
Thank you anyway
713
