Community Member
Outbound call doesn't disconnect after call end
Have you ever seen something like it:
I make a call from my ip phone (3911 or 6921) to an external phone (ex: cell phone: 084645727) and the call works fine, but when cell phone turned off the call, on my ip phone the call still connected,  ip phone  show me on display that the call still active, the call is just disconnect when I put the phone onhook.
I use CUCMBE: 7.1.3(SU2)
Cisco 2821 : c2800nm-spservicesk9-mz.124-20.T4.bin
debug vpm signal
BHEGV1#R2 Got Event R2_ALERTING
*Nov 25 07:42:36: show voice call status
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0xD8803    20E8 0x48177B78 0/1/0:0.3        0/1:1  *2125463737 g711ulaw  7500/40
0xD8847    1C9D 0x48177B78 0/1/0:0.1        0/1:3   7434       g711ulaw  1/7500
0xD88B2    26E8 0x48177B78 0/1/0:0.28       0/1:5  *087068998  g711ulaw  7500/30
0xD88B6    27E8 0x48177B78 0/1/0:0.27       0/1:2  *084645727  g711ulaw  7500/30 (it is my call)
0xD88BD    1D22 0x48177B78 0/1/0:0.2        0/1:4   7491       None      1/7500
0xD88C0    28E8 0x48177B78 0/1/0:0.22       0/1:6  *084743874  g711ulaw  7500/30
After cell phone turned off the call, the debug vpm signal just show me it:
*Nov 25 07:42:50: htsp_process_event: [0/1/0:0(27), R2_Q421_OG_ANSWER, E_DSP_SIG_1100]
Does anybody could help me !
Regards.
Green
Re: Outbound call doesn't disconnect after call end
Ola Evandro
Who is your Service provider?
Please try this config I have for Embratel
controller E1 0/1/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  metering
  country brazil
  double-answer
  disconnect-tone
  category 2
  answer-signal group-b 1
  dnis-digits min 4 max 16
  ani-digits min 4 max 16
  dnis-complete
  trunk-group outgoing
description PSTN-Embratel
If Not Embratel I may be able to find something in particular for your Provider in Brazil
Muito obrigado
Community Member
Hi Gogasca
My service provider is Oi (Telemar).
An interesting thing is that this issue just happen when i place a call from my ip phone to PSTN, when i receive a call from cell phone and cell phone disconnect the call, it works fine.
Are you from Brazil ?
Community Member
Same issue, but with FXO
Same issue, but with FXO ports and same provider
Community Member
Olá pessoal !
Olá pessoal !
Estou com este mesmo problema de não desconectar a chamada. (EMBRATEL e OI ).
Meus roteadores já estão na Versão 15.0
Alguém conseguiu uma solução ?
Agradeço !
Community Member
Hi, I´m facing the same problem with the service provider Oi, could you help me with this case.
Thanks.
Hall of Fame Super Gold
Are you using FXO or E1 R2 ?
Community Member
I´m using E1 R2
Follow my controller configuration:
controller E1 1/1
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
  country brazil
  metering
  release-ack
  category 2
description OI (OUTGOING&INCOMING)
Try the following and confirm if it happens:
Test 1: Outside phone calls CM phone. Answer, talk, then outside phone hangs up. CM phone also disconnects.
Test 2: CM phone calls the outside phone, Answer, talk then outside phone hangs up. CM phone still show conneected.
This happens because some telco only allows the calling party to disconnect, and CM cannot do anything about.
The solution is that when conversation endse, user manually hangs up CM phone.
Hi All
I had this issue with Oi and EBT, not sure if this is the same, but i had an issue where the Voice channel in clearfwd - I was facing the Bug CSCtd74470, there a workaround but the upgrade of the GW to Version 15 works properly, the output of the "sh vo po sum | include clearfwd" will confirm if this is your case.
Also in others situations I solved my issue applying the command timeouts call-disconect 3, under E1 Port
Please rate this post
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
bruno rangel wrote:
Hi All
I had this issue with Oi and EBT, not sure if this is the same, but i had an issue where the Voice channel in clearfwd - I was facing the Bug CSCtd7447, there a workaround but the upgrade of the GW to Version
That is not a valid bug ID.
Hi Paolo did you mean not valid for this case right?
Cheers
Bruno Rangel
Renato Russo
Found it, it's CSCtd74470
However it doen 't seem to match the case, for which I've indicated the most likely cause above.
Thanks, I just edit my post (+5)
Cheers
Bruno Rangel
Renato Russo
Community Member
Hi Bruno, I think it´s not my case because I´m using the version 15.1(4)M.
But I ´will try to use the command you suggested.
Thank you.
Community Member
I have the same issue but in
I have the same issue but in my case is with FXO port, my service provider is IO. can you help me please.
943
