Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Outbound call failing with cause code 57
our outbound calls to some numbers getting failed with cause code 57 and in ccsip messages i am getting 403 forbidden.
i tried to change the payload type to 97 which was 98 but no success.
the called number is 9-8955900
the calling number is 8062300
can any one help me..
the ccsip messages and ccapi inout debug is..
____________________________________________________________________________________
509022: *Jan  8 14:23:20.513: :FEATURE_VSA attributes are: feature_name:0,featur        e_time:1255632752,feature_id:53127
509023: *Jan  8 14:23:20.513: //678454/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPr        ivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
509024: *Jan  8 14:23:20.513: //678454/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x4AC5D304
509025: *Jan  8 14:23:20.517: //678454/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x48D4E620, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
509026: *Jan  8 14:23:20.517: //678454/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
509027: *Jan  8 14:23:20.537: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:8955900@192.168.33.5:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.12.190:5060;branch=z9hG4bK6aded64034252
From: "Asif CIPC" <sip:3064@192.168.12.190>;tag=2524413~70e9433b-1d79-44ae-9a16-        09a52be377c5-22878662
To: <sip:8955900@192.168.33.5>
Date: Wed, 08 Jan 2014 14:02:15 GMT
Call-ID: 7916d300-2cd15a67-4bec7-be0ca8c0@192.168.12.190
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE,        NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 2031538944-0000065536-0000027607-3188500672
Session-Expires:  1800
P-Asserted-Identity: "Asif CIPC" <sip:3064@192.168.12.190>
Remote-Party-ID: "Asif CIPC" <sip:3064@192.168.12.190>;party=calling;screen=yes;        privacy=off
Contact: <sip:3064@192.168.12.190:5060;transport=tcp>
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 240
v=0
o=CiscoSystemsCCM-SIP 2524413 1 IN IP4 192.168.12.190
s=SIP Call
c=IN IP4 192.168.33.5
t=0 0
m=audio 17706 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=ptime:20
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
509028: *Jan  8 14:23:20.553: //-1/7916D3000000/CCAPI/cc_api_display_ie_subfield        s:
   cc_api_call_setup_ind_common:
   cisco-username=3064
   ----- ccCallInfo IE subfields -----
   cisco-ani=3064
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8955900
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
509029: *Jan  8 14:23:20.553: /
ASICO-DAM#/-1/7916D3000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x48667600, Call Info(
   Calling Number=3064,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User,        Passed, Presentation=Allowed),
   Called Number=8955900(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T        RUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS        E), Call Id=678455
509030: *Jan  8 14:23:20.553: //-1/7916D3000000/CCAPI/ccCheckClipClir:
   In: Calling Number=3064(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pre        sentation=Allowed)
509031: *Jan  8 14:23:20.553: //-1/7916D3000000/CCAPI/ccCheckClipClir:
   Out: Calling Number=3064(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pr        esentation=Allowed)
509032: *Jan  8 14:23:20.553: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509033: *Jan  8 14:23:20.553: :cc_get_feature_vsa malloc success
509034: *Jan  8 14:23:20.553: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509035: *Jan  8 14:23:20.553:  cc_get_feature_vsa count is 13
509036: *Jan  8 14:23:20.553: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509037: *Jan  8 14:23:20.553: :FEATURE_VSA attributes are: feature_name:0,featur        e_time:1255634768,feature_id:53128
509038: *Jan  8 14:23:20.553: //678455/7916D3000000/CCAPI/cc_api_call_setup_ind_        common:
   Set Up Event Sent;
   Call Info(Calling Number=3064(TON=Unknown, NPI=Unknown, Screening=User, Passe        d, Presentation=Allowed),
   Called Number=8955900(TON=Unknown, NPI=Unknown))
509039: *Jan  8 14:23:20.557: //678455/7916D3000000/CCAPI/cc_process_call_setup_        ind:
   Event=0x48EE6200
509040: *Jan  8 14:23:20.557: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 8955900
509041: *Jan  8 14:23:20.561: //678455/7916D3000000/CCAPI/ccCallSetContext:
   Context=0x476E35D0
509042: *Jan  8 14:23:20.561: //678455/7916D3000000/CCAPI/cc_process_call_setup_        ind:
   >>>>CCAPI handed cid 678455 with tag 1 to app "_ManagedAppProcess_Default"
509043: *Jan  8 14:23:20.561: //678455/7916D3000000/CCAPI/ccCallProceeding:
509044: *Jan  8 14:23:20.565: //678455/7916D3000000/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20, Params=0x476E4AE0, Progress Indication=NULL(0)
509045: *Jan  8 14:23:20.565: //678455/7916D3000000/CCAPI/ccCheckClipClir:
   In: Calling Number=8062301(TON=Unknown, NPI=Unknown, Screening=User, Passed,        Presentation=Allowed)
509046: *Jan  8 14:23:20.565: //678455/7916D3000000/CCAPI/ccCheckClipClir:
   Out: Calling Number=8062301(TON=Unknown, NPI=Unknown, Screening=User, Passed,        Presentation=Allowed)
509047: *Jan  8 14:23:20.565: //678455/7916D3000000/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=8955900, Digit Strip=FALSE
509048: *Jan  8 14:23:20.565: //678455/7916D3000000/CCAPI/ccCallSetupRequest:
   Calling Number=8062301(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pres        entation=Allowed),
   Redirect Number=, Display Info=Asif CIPC
   Account Number=3064, Final Destination Flag=TRUE,
   Guid=7916D300-0001-0000-0000-6BD7BE0CA8C0, Outgoing Dial-peer=20
509049: *Jan  8 14:23:20.565: //678455/7916D3000000/CCAPI/cc_api_display_ie_subf        ields:
   ccCallSetupRequest:
   cisco-username=3064
   cisco-ani=8062301
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8955900
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
509050: *Jan  8 14:23:20.569: //678455/7916D3000000/CCAPI/ccIFCallSetupRequestPr        ivate:
   Interface=0x48667600, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=8062301,(Calling Name=Asif CIPC)(TON=Unknown, NPI=        Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8955900(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20        , Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl        ication Call Id=)
509051: *Jan  8 14:23:20.569: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509052: *Jan  8 14:23:20.569: :cc_get_feature_vsa malloc success
509053: *Jan  8 14:23:20.569: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509054: *Jan  8 14:23:20.569:  cc_get_feature_vsa count is 14
509055: *Jan  8 14:23:20.569: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509056: *Jan  8 14:23:20.569: :FEATURE_VSA attributes are: feature_name:0,featur        e_time:1255629840,feature_id:53129
509057: *Jan  8 14:23:20.569: //678456/7916D3000000/CCAPI/ccIFCallSetupRequestPr        ivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
509058: *Jan  8 14:23:20.573: //678456/7916D3000000/CCAPI/ccCallSetContext:
   Context=0x476E4A90
509059: *Jan  8 14:23:20.573: //678455/7916D3000000/CCAPI/ccSaveDialpeerTag:
509060: *Jan  8 14:23:20.577: //678456/7916D3000000/CCAPI/cc_api_call_proceeding        :
   Interface=0x48667600, Progress Indication=NULL(0)
509061: *Jan  8 14:23:20.585: //678456/7916D3000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8955900@10.205.20.50:5060 SIP/2.0
Via: SIP/2.0/UDP 172..XX.XX.XX:5060;branch=z9hG4bK67CD11AE
Remote-Party-ID: "Asif CIPC" <sip:8062301@172..XX.XX.XX>;party=calling;screen=ye        s;privacy=off
From: "Asif CIPC" <sip:8062301@172..XX.XX.XX>;tag=EA475228-24AE
To: <sip:8955900@10.205.20.50>
Date: Wed, 08 Jan 2014 14:23:20 GMT
Call-ID: 423CC9E8-77A711E3-B17FC811-504F9B5B@172..XX.XX.XX
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF        Y, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1389191000
Contact: <sip:8062301@172..XX.XX.XX:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 5380 1731 IN IP4 172..XX.XX.XX
s=SIP Call
c=IN IP4 172..XX.XX.XX
t=0 0
m=audio 19502 RTP/AVP 18 101
a=fmtp:18 annexb=yes
a=fmtp:101 0-15
a=ptime:20
509062: *Jan  8 14:23:20.589: //678455/7916D3000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: kpml, telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
509063: *Jan  8 14:23:20.605: //678456/7916D3000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Asif CIPC"<sip:8062301@172..XX.XX.XX>;tag=EA475228-24AE
CSeq: 101 INVITE
Content-Length: 0
509064: *Jan  8 14:23:20.677: //678456/7916D3000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
Record-Route: <sip:10.205.20.50:5060;transport=udp;lr>
To: <sip:8955900@10.205.20.50>;tag=sbc0804k7h28358
CSeq: 101 INVITE
Reason: Q.850;cause=57;text="bearer capability not authorized"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
509065: *Jan  8 14:23:20.677: //678456/7916D3000000/CCAPI/cc_api_call_disconnect        ed:
   Cause Value=57, Interface=0x48667600, Call Id=678456
509066: *Jan  8 14:23:20.677: //678456/7916D3000000/CCAPI/cc_api_call_disconnect        ed:
   Call Entry(Responsed=TRUE, Cause Value=57, Retry Count=0)
509067: *Jan  8 14:23:20.681: //678455/7916D3000000/CCAPI/ccCallReleaseResources        :
   release reserved xcoding resource.
509068: *Jan  8 14:23:20.681: //678456/7916D3000000/CCAPI/ccCallSetAAA_Accountin        g:
   Accounting=0, Call Id=678456
509069: *Jan  8 14:23:20.681: //678456/7916D3000000/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C        ause=57)
509070: *Jan  8 14:23:20.681: //678456/7916D3000000/CCAPI/ccCallDisconnect:
   Cause Value=57, Call Entry(Responsed=TRUE, Cause Value=57)
509071: *Jan  8 14:23:20.681: //678456/7916D3000000/CCAPI/cc_api_call_disconnect        _done:
   Disposition=0, Interface=0x48667600, Tag=0x0, Call Id=678456,
   Call Entry(Disconnect Cause=57, Voice Class Cause Code=0, Retry Count=0)
509072: *Jan  8 14:23:20.685: //678456/7916D3000000/CCAPI/cc_api_call_disconnect        _done:
   Call Disconnect Event Sent
509073: *Jan  8 14:23:20.685: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509074: *Jan  8 14:23:20.685: :cc_free_feature_vsa freeing 4AD76408
509075: *Jan  8 14:23:20.685: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509076: *Jan  8 14:23:20.685:  vsacount in free is 13
509077: *Jan  8 14:23:20.685: //678455/7916D3000000/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C        ause=0)
509078: *Jan  8 14:23:20.689: //678455/7916D3000000/CCAPI/ccCallDisconnect:
509079: *Jan  8 14:23:20.693: //678455/7916D3000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:8955900@192.168.33.5>;tag=EA475298-106E
CSeq: 101 INVITE
Content-Length: 0
509080: *Jan  8 14:23:20.693: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:8955900@10.205.20.50:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
509081: *Jan  8 14:23:20.709: //678454/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca        use=0)
509082: *Jan  8 14:23:20.709: //678454/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
509083: *Jan  8 14:23:20.709: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:8955900@192.168.33.5:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
509084: *Jan  8 14:23:20.713: //678455/7916D3000000/CCAPI/cc_api_call_disconnect        _done:
   Disposition=0, Interface=0x48667600, Tag=0x0, Call Id=678455,
509085: *Jan  8 14:23:20.717: //678455/7916D3000000/CCAPI/cc_api_call_disconnect        _done:
509086: *Jan  8 14:23:20.717: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509087: *Jan  8 14:23:20.717: :cc_free_feature_vsa freeing 4AD77748
509088: *Jan  8 14:23:20.717: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509089: *Jan  8 14:23:20.717:  vsacount in free is 12
509090: *Jan  8 14:23:20.721: //678454/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect        _done:
   Disposition=0, Interface=0x48D4E620, Tag=0x0, Call Id=678454,
   Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
509091: *Jan  8 14:23:20.721: //678454/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect        _done:
509092: *Jan  8 14:23:20.721: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509093: *Jan  8 14:23:20.721: :cc_free_feature_vsa freeing 4AD76F68
509094: *Jan  8 14:23:20.721: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509095: *Jan  8 14:23:20.721:  vsacount in free is 11
509096: *Jan  8 14:23:20.725: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivat        e:
   Interface=0x48D4E620, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screeni        ng=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call        Count On=FALSE,
509097: *Jan  8 14:23:20.725: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509098: *Jan  8 14:23:20.725: :cc_get_feature_vsa malloc success
509099: *Jan  8 14:23:20.725: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509100: *Jan  8 14:23:20.729:  cc_get_feature_vsa count is 12
509101: *Jan  8 14:23:20.729: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509102: *Jan  8 14:23:20.729: :FEATURE_VSA attributes are: feature_name:0,featur        e_time:1255632752,feature_id:53130
509103: *Jan  8 14:23:20.729: //678457/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPr        ivate:
509104: *Jan  8 14:23:20.729: //678457/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x4AC5D1C4
509105: *Jan  8 14:23:20.729: //678457/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
509106: *Jan  8 14:23:20.729: //678457/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
509107: *Jan  8 14:23:20.753: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.12.190:5060;branch=z9hG4bK6adee3e42a498
From: "Asif CIPC" <sip:3064@192.168.12.190>;tag=2524415~70e9433b-1d79-44ae-9a16-        09a52be377c5-22878662
Call-ID: 7916d300-2cd15a67-4bec8-be0ca8c0@192.168.12.190
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 2031538944-0000065536-0000027608-3188500672
Max-Forwards: 70
Content-Length: 240
v=0
o=CiscoSystemsCCM-SIP 2524415 1 IN IP4 192.168.12.190
s=SIP Call
t=0 0
m=audio 17932 RTP/AVP 18 101
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
509108: *Jan  8 14:23:20.769: //-1/7916D3000000/CCAPI/cc_api_display_ie_subfield        s:
   cisco-username=3064
   cisco-ani=3064
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8955900
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
509109: *Jan  8 14:23:20.769: //-1/7916D3000000/CCAPI/cc_api_call_setup_ind_comm        on:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS        E), Call Id=678458
509110: *Jan  8 14:23:20.769: //-1/7916D3000000/CCAPI/ccCheckClipClir:
509111: *Jan  8 14:23:20.773: //-1/7916D3000000/CCAPI/ccCheckClipClir:
509112: *Jan  8 14:23:20.773: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509113: *Jan  8 14:23:20.773: :cc_get_feature_vsa malloc success
509114: *Jan  8 14:23:20.773: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509115: *Jan  8 14:23:20.773:  cc_get_feature_vsa count is 13
509116: *Jan  8 14:23:20.773: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509117: *Jan  8 14:23:20.773: :FEATURE_VSA attributes are: feature_name:0,featur        e_time:1255634768,feature_id:53131
509118: *Jan  8 14:23:20.773: //678458/7916D3000000/CCAPI/cc_api_call_setup_ind_        common:
   Set Up Event Sent;
509119: *Jan  8 14:23:20.773: //678458/7916D3000000/CCAPI/cc_process_call_setup_        ind:
   Event=0x48EE6200
509120: *Jan  8 14:23:20.777: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
509121: *Jan  8 14:23:20.777: //678458/7916D3000000/CCAPI/ccCallSetContext:
   Context=0x476D5190
509122: *Jan  8 14:23:20.777: //678458/7916D3000000/CCAPI/cc_process_call_setup_        ind:
   >>>>CCAPI handed cid 678458 with tag 1 to app "_ManagedAppProcess_Default"
509123: *Jan  8 14:23:20.777: //678458/7916D3000000/CCAPI/ccCallProceeding:
509124: *Jan  8 14:23:20.781: //678458/7916D3000000/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20, Params=0x476DCE60, Progress Indication=NULL(0)
509125: *Jan  8 14:23:20.781: //678458/7916D3000000/CCAPI/ccCheckClipClir:
509126: *Jan  8 14:23:20.781: //678458/7916D3000000/CCAPI/ccCheckClipClir:
509127: *Jan  8 14:23:20.785: //678458/7916D3000000/CCAPI/ccCallSetupRequest:
509128: *Jan  8 14:23:20.785: //678458/7916D3000000/CCAPI/ccCallSetupRequest:
   Guid=7916D300-0001-0000-0000-6BD8BE0CA8C0, Outgoing Dial-peer=20
509129: *Jan  8 14:23:20.785: //678458/7916D3000000/CCAPI/cc_api_display_ie_subf        ields:
   ccCallSetupRequest:
   cisco-username=3064
   cisco-ani=8062301
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8955900
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
509130: *Jan  8 14:23:20.785: //678458/7916D3000000/CCAPI/ccIFCallSetupRequestPr        ivate:
509131: *Jan  8 14:23:20.785: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509132: *Jan  8 14:23:20.785: :cc_get_feature_vsa malloc success
509133: *Jan  8 14:23:20.785: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509134: *Jan  8 14:23:20.785:  cc_get_feature_vsa count is 14
509135: *Jan  8 14:23:20.785: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
509136: *Jan  8 14:23:20.785: :FEATURE_VSA attributes are: feature_name:0,featur        e_time:1255629840,feature_id:53132
509137: *Jan  8 14:23:20.789: //678459/7916D3000000/CCAPI/ccIFCallSetupRequestPr        ivate:
509138: *Jan  8 14:23:20.789: //678459/7916D3000000/CCAPI/ccCallSetContext:
   Context=0x476DCE10
509139: *Jan  8 14:23:20.789: //678458/7916D3000000/CCAPI/ccSaveDialpeerTag:
509140: *Jan  8 14:23:20.793: //678459/7916D3000000/CCAPI/cc_api_call_proceeding        :
509141: *Jan  8 14:23:20.801: //678459/7916D3000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172..XX.XX.XX:5060;branch=z9hG4bK67CE197B
From: "Asif CIPC" <sip:8062301@172..XX.XX.XX>;tag=EA475304-26C5
Call-ID: 425DBF1A-77A711E3-B186C811-504F9B5B@172..XX.XX.XX
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 9218 9584 IN IP4 172..XX.XX.XX
s=SIP Call
t=0 0
m=audio 16868 RTP/AVP 18 101
a=fmtp:101 0-15
a=ptime:20
509142: *Jan  8 14:23:20.805: //678458/7916D3000000/SIP/Msg/ccsipDisplayMsg:
Sent:
509163: *Jan  8 14:23:20.945: //678458/7916D3000000/CCAPI/cc_api_call_disconnect        _done:
509164: *Jan  8 14:23:20.945: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509165: *Jan  8 14:23:20.945: :cc_free_feature_vsa freeing 4AD77748
509166: *Jan  8 14:23:20.945: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
509167: *Jan  8 14:23:20.945:  vsacount in free is 12
509168: *Jan  8 14:23:32.517: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172..XX.XX.XX:5060 SIP/2.0
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKhs8ak5845ch42p7cff35k1ap3T02677
Call-ID: isbchh12748fcsk155w58p151kks36fww24s@SoftX3000
To: <sip:172..XX.XX.XX>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
509169: *Jan  8 14:23:32.525: //678460/495AB05FB187/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172..XX.XX.XX>;tag=EA4780CC-582
Date: Wed, 08 Jan 2014 14:23:32 GMT
CSeq: 1 OPTIONS
Accept: application/sdp
Content-Length: 170
v=0
o=CiscoSystemsSIP-GW-UserAgent 8937 2437 IN IP4 172..XX.XX.XX
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
u all
and the config is
voice service voip
ip address trusted list
  ipv4 172.XX.XX.XX 255.255.255.255
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h225-notify cid-update
redirect ip2ip
h323
  session transport udp
  h245 tunnel disable
sip
  session transport tcp
  rel1xx disable
  registrar server expires max 3600 min 3500
  transport switch udp tcp
  redirect contact order best-match
  asymmetric payload full
  g729 annexb-all
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
and the dial-peer through the calls will go out is
dial-peer voice 20 voip
description ***TO-OUT***
translation-profile outgoing OUT-SIP
destination-pattern .T
progress_ind progress enable 8
rtp payload-type cisco-codec-fax-ack 112
rtp payload-type nte 97
session protocol sipv2
session target ipv4:10.205.20.50:5060
voice-class codec 1
voice-class sip bind control source-interface FastEthernet0/0
voice-class sip bind media source-interface FastEthernet0/0
dtmf-relay rtp-nte
no vad
Everyone's tags (1)
1 ACCEPTED SOLUTION
what is the region name configured for Trunks? are they using default region?
As per the RE_KHBR.PNG attachment, when the calls initiated from KHBR region to other sites, they will use G729 codec.
but for ITSP, the call should use G711A codec. to avoid this mismatch, we need to have Transcoders added to SIP Trunk MRGL in CUCM or change the region settings between KHBR_Region to Trunk Regions(?) to G711.
please let me know which one we can try for.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Hello Mohammed
What is call flow topology?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hi Nadeem,
our setup is like
                                                            vpn link
call manager ------head office(router)----------------------------------brach router(gateway)------------------ip phone(branch)
The call flow is
        sip
IP Phone---->brach GW-------------->call manager------------------>branch GW------------------->ITSP
there is no subscriber at branch side, so the outbound call should travel to call manager at head office and then get exit from branch gateway to ITSP through sip line.
Hello Mohammed,
The call to ITSP uses G729 codec. so the call is disconnected with "Reason: Q.850;cause=57;text="bearer capability not authorized"
have you configured the region between the branch phone and the SIP trunk to use G729?
what is the codec supported by your ITSP? G711 or G729?
could you please try changing the device pool for one of the branch phones same as the SIP trunk device pool and check the behaviour please?
Re: Outbound call failing with cause code 57
ITSP says its using 711alaw but the call is negotiating on 729.
yes the same device pool is being used as sip trunk on my phone but the call is getting failed. not all but only to few numbers.
is the call failing for all the phone models or only for CIPC?
it seems the calling device is CIPC. have you checked 'optimize for low bandwidth' in your CIPC?
if so, could you please uncheck it and try again?
when you make call from Head office phone (CIPC or IP phone) to same number, does the call still fail?
yes the call is failing with all phones ( cp-8941, and cp-6921 and CIPC)
Is it working from headoffice phones for the same number ?
If so, it should be negotiating G711A with provider ?
Also we need to crosscheck why the branch office phones negotiating G729? Please collect detailed ccm traces for a non working call?
Hi Suresh,
Its working with headoffice phones, i will collect the debugs from head office gw now..
Please collect ccm traces for the branch office call to understand why it's negotiating G729?
I would like you to crosscheck the region setting of the phones.once again?
Hi Suresh,
i cheched the region settings , its g.722 and g.711 to the trunk and g.729 to others.
attached traces, please have a look...
Mohammed, the call is not available in the traces. could you please crosscheck and provide the correct traces again?
Hi suresh,
sorry, the DN was 2064.
now attacching the traces with called number 9-8955900 calling number 3064
No, still not available. please collect the detailed ccm traces from all the nodes for a test call. Also please crosscheck if the particular call is available in the traces before uploading.
Hi Suresh,
Sorry i was collecting SDL logs, here is the SDI log..
This is not the SDI trace again. this is Calllog trace.
i am very sorry, this  is call log traces from SDI whichi collected...
attaching another..
The call is not available in the trace. Please collect fresh ccm traces from all the nodes and attach it.
Hi Suresh,
i am really sorry.
i was collecting the logs from both pub and sub, as detailed and sdi.follwing the doc
https://supportforums.cisco.com/docs/DOC-29901
attached is a snapshot from servisability.
can you please tell me where i am doing wrong.
In RTMT, you may try using 'Relative Range - Files generated in last 5 mins' instead of 'Absolute range - From & To time stamp'
Also in outgoing dial-peer (dial-peer voice 20 voip) instead of 'voice-class codec 1', could you please try the command 'codec g711alaw' or create voice-class codec 2 only with G711 alaw codec under that and apply it to dial-peer 20?
do you have transcoder configured in CUCM SIP Trunk MRGL?
Hi Suresh,
i was selecting 30 min range as there was no other call traffic, and i think you saw the call in call log trace doc
but not in SDI trace files, and today morning also i tried with that but unable to find the calls in trace.
i hard coded the codec g711alaw on dial-peer 20 yesterday, but still its negotiating on g729.
1) with g711alaw codec hardcoded to dial-peer, could you please collect 'debug ccsip message & debug voice ccapi inout' for a test call again? please provide the cube config also.
2) but it is good to have ccm trace to find out why the branch site calls are using g729 codec. beyond region settings, i couldn't think of any other clues. could you please reconfigure a branch phone with 'HQ devicepool and test the behaviour?
if that doesn't work, collect another set of debug for that call also.
please let me know the calling & called party details while uploading the logs for those 2 set of test calls
ok i will hard code the codec and collect the debugs after work hours, as it is now in production.
i configured a branch phone as HQ phone and tested that its working fine. but with the branch device pool its not working.
can we configure toll bypass for the specific number to get exit from head office sip line because they have to call the number many times.
i tried that but failed.
Please check the region setting difference between the HQ device pool and BR Device Pool & also the trunk device pool
Region Relationship ( if there is seperate region configured for trunk)
codec used between RE_HQ & RE_TRUNK = ?
codec used between RE_BR & RE_TRUNK = ?
codec used between RE_HQ & RE_BR = ?
Codec used between the braches is G.729
but for gateways and trunks G.722 and G.711
just have a look at the attachments of head office and branch region
now changed the codec between the branch and head office from g.729 to g.711 and its working.
Thanks a ton suresh..
Hi Mohammed, good to know the issue is fixed. Glad that I could help.
Thanks for the rating.
3669
