outbound call fails for a particular number
HI  have call manager version 8.6 and VGW 3845 with IOS version flash:c3845-advipservicesk9-mz.124-24.T6.bin"
outbound call to one particular number fails intermittently failure ratio is 3/5 almost.
when the call goes via one gateway output is ,
Mar 12 20:50:26.662 CST: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x0        125
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Display i = 'Shuda Wang 8613113'
        Calling Party Number i = 0x4081, '85303113'
                Plan:Unknown, Type:Subscriber(local)
        Called Party Number i = 0x91, '00441913351934'
                Plan:ISDN, Type:International
Mar 12 20:50:26.774 CST: ISDN Se0/0/1:15 Q931: RX <- STATUS pd = 8  callref = 0x        8125
        Cause i = 0x82E328 - Information element not implemented
        Call State i = 0x01
Mar 12 20:50:27.034 CST: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref =        0x8125
Mar 12 20:50:41.954 CST: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref        = 0x8125
        Cause i = 0x84EF - Protocol error; unspecified
        Progress Ind i = 0x8288 - In-band info or appropriate now available
from another GW the output is ,
Mar 12 20:44:01.770 CST: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x0        123
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9839B
                Exclusive, Channel 27
Mar 12 20:44:02.126 CST: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref =        0x8123
Mar 12 20:44:13.235 CST: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref        = 0x8124
        Cause i = 0x8090 - Normal call clearing
Mar 12 20:44:13.271 CST: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0        x0124
Mar 12 20:44:13.343 CST: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callre        f = 0x8124
Mar 12 20:44:22.507 CST: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8123
        Cause i = 0x82E6 - Recovery on timer expiry
Mar 12 20:44:47.772 CST: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0125
I suspect it could be servic eprovider issue as he issue happens only for one number and also intermittent.
please suggest.
Hello Baskaran, As you
Hello Baskaran,
As you receive the disconnect message from your provider, please talk to them on why they are disconnecting the call.
http://www.cisco.com/c/en/us/support/docs/dial-access/integrated-services-digital-networks-isdn-channel-associated-signaling-cas/8607-isdn-disc-code.html
84—the public network near the remote user (remote telco switch)
EFProtocol error, unspecified
This cause indicates an unspecified D-channel error with no other standard cause.
//Suresh Please rate all the useful posts.
Hi Baskaran,Can you please
Hi Baskaran,
Can you please share your debug of successfull and unsuccessful for the same number for which you are facing intermitent issue.
In that you can compare for the "Transfer Rate = 64 kbit/s" and check if you find any variation between both the calls.
Another possibility is that the call from your VGW to destination is not direct i.e once call arrives to PSTN they may be directing that call through differnent path to reach to the destination.
Nishant Savalia
Regards, Nishant Savalia
95
