Community Member
Outbound Call Failure - SIP Trunk
All phones are unable to dial a single target number on the PSTN.  The symptom is that it rings once and goes fast busy.
The call flow is:
Phone >>> CUCM >>> CUBE >>> Verizon SIP Trunk >>> PSTN >>> Target Number
As seen in the CUBE debug ccsip messages, the CUBE receives a "SIP/2.0 480 Temporarily unavailable" message.  debug ccsip messages, dial-peer and voice class information follows:
Received:
INVITE sip:1XXX-XXX-XXXX@10.139.64.52:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.106.11:5060;branch=z9hG4bK6c4bb65f140c8
From: "" <sip:XXX-XXX-XXXX@192.168.106.11>;tag=4037968~a812c08a-f7f0-43a7-a92c-e5ac2a38867c-65745615
To: <sip:1XXX-XXX-XXXX@10.139.64.52>
Date: Wed, 18 Dec 2013 21:48:27 GMT
Call-ID: 1f068d00-2b21182b-fc6d-b6aa8c0@192.168.106.11
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:192.168.106.11:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 0520523008-0000065536-0000067523-0191539392
Session-Expires:  1800
P-Asserted-Identity: "" <sip:XXX-XXX-XXXX@192.168.106.11>
Remote-Party-ID: "" <sip:XXX-XXX-XXXX@192.168.106.11>;party=calling;screen=yes;privacy=off
Contact: <sip:XXX-XXX-XXXX@192.168.106.11:5060;transport=tcp>
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 390
v=0
o=CiscoSystemsCCM-SIP 4037968 1 IN IP4 192.168.106.11
s=SIP Call
c=IN IP4 10.139.64.171
b=TIAS:64000
b=AS:64
t=0 0
m=audio 30688 RTP/AVP 0 8 116 18 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:116 iLBC/8000
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Sent:
INVITE sip:1XXX-XXX-XXXX@10.189.135.17:5073 SIP/2.0
Via: SIP/2.0/UDP 10.139.64.52:5060;branch=z9hG4bK636B313D7
Remote-Party-ID: "" <sip:XXX-XXX-XXXX@10.139.64.52>;party=calling;screen=yes;privacy=off
From: "" <sip:XXX-XXX-XXXX@10.139.64.52>;tag=78FC5414-198D
To: <sip:1XXX-XXX-XXXX@10.189.135.17>
Date: Wed, 18 Dec 2013 21:40:10 GMT
Call-ID: CD993954-676311E3-8734DBF2-34273F6B@10.139.64.52
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1387402810
Contact: <sip:XXX-XXX-XXXX@10.139.64.52:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 348
v=0
o=CiscoSystemsSIP-GW-UserAgent 4778 3356 IN IP4 10.139.64.52
s=SIP Call
c=IN IP4 10.139.64.52
t=0 0
m=audio 23372 RTP/AVP 0 8 116 18 101
a=fmtp:116
a=fmtp:18 annexb=yes
a=fmtp:101 0-15
079120: Dec 18 2013 16:40:10.008: //314738/1F068D000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 18 Dec 2013 21:40:09 GMT
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
079121: Dec 18 2013 16:40:10.080: //314739/1F068D000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
079122: Dec 18 2013 16:40:11.176: //314739/1F068D000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:1XXX-XXX-XXXX@10.189.135.17>;tag=182903799-1387403308449
CSeq: 101 INVITE
Supported:
Contact: <sip:1XXX-XXX-XXXX@10.189.135.17:5073;transport=udp>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
To: <sip:1XXX-XXX-XXXX@10.139.64.52>;tag=78FC58A8-1B6B
CSeq: 101 INVITE
Remote-Party-ID: <sip:1XXX-XXX-XXXX@10.139.64.52>;party=called;screen=no;privacy=off
Contact: <sip:1XXX-XXX-XXXX@10.139.64.52:5060;transport=tcp>
Content-Length: 0
079128: Dec 18 2013 16:40:12.384: //314739/1F068D000001/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
Sent:
SIP/2.0 480 Temporarily Not Available
CSeq: 101 INVITE
Reason: Q.850;cause=18
Content-Length: 0
079146: Dec 18 2013 16:40:12.388: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1XXX-XXX-XXXX@10.189.135.17:5073 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
079147: Dec 18 2013 16:40:12.404: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1XXX-XXX-XXXX@10.139.64.52:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
dial-peer voice 9100 voip
description inboubd dial-peer for outgoing calls from CUCM (11D)
preference 1
session protocol sipv2
incoming called-number ^1..........$
voice-class codec 10
dtmf-relay rtp-nte digit-drop
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
outbound DP
dial-peer voice 8100 voip
description outbound dial-peer for outgoing calls to Verizon (11D)
destination-pattern ^1..........$
session target sip-server
voice-class sip dtmf-relay force rtp-nte
voice-class sip early-offer forced
no vad
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class codec 10
codec preference 1 transparent
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g722-64
Everyone's tags (2)
1 ACCEPTED SOLUTION
VIP Super Bronze
Open a ticket with Verizon..This is an issue on their side. They are not able to route the call to this number, they  need to tell you why
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Community Member
Thank you!  That was my conclusion as well.
Amir
Community Member
Please see the reply from Verizon as follows.  Does this make sense to you?
On the invite we are receiving, includes a codec in the SDP that is not supported over our network. Can you please remove this option and retest the call.
Codec
116 iLBC/8000 is not supported over our network and is causing the Long Distance gateway to fail the call
fmtp:116
VIP Super Bronze
Yes it does..The INVITE from CUCM has ilbc codec in it..Here is the SDP portion of the INVITE
t=0 0
a=ptime:20
a=ptime:20
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=ptime:20
You can disable ilbc on CUCM by going to CUCM service parameters, then slect call manager> click on advanced settings and look for "iLBC Codec Enabled" and set it to false.
Community Member
Re: Outbound Call Failure - SIP Trunk
Ah - this will require a change management process.  Do you see any downside in disabling this codec?  What end points are using this codec?
Or better yet - can I disable this at the CUBE "only" so that I can first confirm that this resolves the issue?  Thus not disabling it globally within CUCM.
VIP Super Bronze
Ignore my first post..Leave voice class codec 10..
voice class codec 11
codec preference 2 g711alaw
codec preference 3 g729r8
no voice-class codec 10
voice-class codec 11
Then apply this to your outbound dial-peer
Community Member
I created the new voice class and mapped it to the outgoing dial-peer 8100. The call was then successful.
See new voice class:
#sh run | be voice class codec 11
See revised dial-peer 8100:
no vad
My only remaining question is why did the CUBE invite NOT include the m line for g729r8?
See the ccapi inout snippet showing the hit with dial-peer 8100:
080927: Dec 19 2013 15:27:57.810: //316459/32C4F8800001/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=8100, Params=0x2B912E08, Progress Indication=NULL(0)
See the debug ccsip messages output showing original CUCM invite received by CUBE with 5 a line references:
080907: Dec 19 2013 15:27:57.806: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:XXXXXXXXXX@10.139.64.52:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.106.11:5060;branch=z9hG4bK6d715c9c6ad1
From: "XXXXXXXXXX" ;tag=4077346~a812c08a-f7f0-43a7-a92c-e5ac2a38867c-65761788
To:
Date: Thu, 19 Dec 2013 20:36:14 GMT
Call-ID: 32c4f880-2b3158be-ffc1-b6aa8c0@192.168.106.11
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Call-Info: <192.168.106.11:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 0851769472-0000065536-0000068412-0191539392
P-Asserted-Identity: "XXXXXXXXXX"
Remote-Party-ID: "XXXXXXX" ;party=calling;screen=yes;privacy=off
Contact:
Max-Forwards: 70
Content-Length: 464
v=0
o=CiscoSystemsCCM-SIP 4077346 1 IN IP4 192.168.106.11
s=SIP Call
b=TIAS:64000
b=AS:64
t=0 0
m=audio 26738 RTP/AVP 0 8 116 116 18 101
a=ptime:20
a=ptime:20
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=ptime:30
a=maxptime:60
a=fmtp:116 mode=30
a=ptime:20
a=fmtp:101 0-15
See ccsip messages output showing CUBE sending invite to Verizon:
Sent:
INVITE sip:13369272626@10.189.135.17:5073 SIP/2.0
Via: SIP/2.0/UDP 10.139.64.52:5060;branch=z9hG4bK63F9C611
Remote-Party-ID: "David Callahan" <3367036158>;party=calling;screen=yes;privacy=off
From: "David Callahan" <3367036158>;tag=7DE0957C-1CAB
To: <13369272626>
Date: Thu, 19 Dec 2013 20:27:57 GMT
Call-ID: E1D3496E-682211E3-95F4DBF2-34273F6B@10.139.64.52
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1387484877
Contact: <3367036158>
Expires: 180
Max-Forwards: 69
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 6966 4178 IN IP4 10.139.64.52
s=SIP Call
t=0 0
m=audio 32502 RTP/AVP 0 8 101
a=fmtp:101 0-15
VIP Super Bronze
Glad to know its working..Dont forget to rate useful posts or mark as answered any answered question
Thats a good question..and that is strange..Try this..
codec preference 3 g711alaw
Then test again and see if G729 is offered in the m-line to your ITSP..If it is, revert back to the old one and test again, then enable debug ccsip all...(make sure that there is little traffic on the cube when you do this)..Send the logs to me
2446
