outbound caller id on CME 4.1
How can I get the full 10-digit originating number to show up during outbound calls? Right now, the dialed number on PSTN side gets the 4-digit extension.
This should be an easy one -- I've done this many times on CCM, 1st on CCME.
Jad
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: outbound caller id on CME 4.1
There is more than one way. One is "dialplan-pattern 1 555123.... extension-length 4"
beautiful - worked like a charm.
Great. For your information, you're one of the few users in the world allowed to send arbitrary numbers as caller-id. Use that wisely and don't pretend to be someone else, like the White House calling :)
Thanks for the nice rating and good luck!
Nice to know :)
I ran into another problem - once I added the dialplan, calls stopped forwarding to voicemail after 3 rings...it would just go to busy. Removing it fixed the problem, but now i'm back to square one. How can I get both to play nice together?
The thing is likely now, calls going to VM are sent with the full calling number too.
Check debug ccsip message to confirm.
I think something can be done in the VM to accept these numbers as alias of the extension only, if not, there is a simple translation rule you can use instead
voice translation-profile make10
translate calling 10
voice translation-rule 10
rule 1 // /555123/
voice port x/y:23
translation-profile outgoing make10
Thanks again! That translation rule did the job just fine. I wasn't sure about the VM aliases, so didn't mess with that.
Jad
You are very welcome. Now the next part is when your customer will ask that certain extension present DID, others present pilot, and others again present "private" :)
Worry not we'll be here to answer that as well.
150
