Outbound caller ID values on ISDN PRI will not take when transmitted to the PSTN
All,
Below are errors from a Q931 debug for a Vz PRI circuit. caller ID that we place on the line using  is not what goes out to the PSTN. Items that standout are:
  • Cause i = 0x82E46C - Invalid information element contents
  • Cause i = 0x82AB6C - Access information discarded
The ISDN line config on our end is:
controller T1 0/0/0
 cablelength long 0db
 pri-group timeslots 1-24
isdn switch-type primary-ni
 isdn incoming-voice voice
 isdn map address . plan unknown type unknown
Ideas?
Oct 29 21:59:57.497 GMT: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0AEB
    Bearer Capability i = 0x8090A2
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98397
        Exclusive, Channel 23
    Progress Ind i = 0x8183 - Origination address is non-ISDN
    Calling Party Number i = 0x0080, '7605551212'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '14155551212'
Oct 29 21:59:57.561 GMT: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8  callref = 0x8AEB
    Call State i = 0x01
  • IP Telephony
Everyone's tags (1)
Hi,I am based in the UK so I
I am based in the UK so I am not sure if this will apply in your country but what I do is capture the debug isdn q931 for an incoming call and then use voice translation rules to make sure what gets sent on outbound calls matches in terms of number of digits etc.
This is what I did for a PRI
This is what I did for a PRI T1 site, H323 gateway and CUCM not CME
In CUCM 9.1 under DEVICE/GATEWAY/ on the gateway we have/Call Routing Information - Outbound Calls/Caller ID DN/PUT IN THE NUMBER YOU WANT TO GO OUT
see attached picture.
Thanks for the response. I
Thanks for the response. I should have mentioned that this location uses a Callmanager Express (CME). The entire config resides on the router.
361
