Outbound Caller ID
I'm new to all this and I'm setting up my first voip system. Everything is working but my company wants to show a single phone number from all calls made from our ip phone system. Example; our DIDs are 555-51xx with xx matching the extension number. We want them all to show 520-555-1234. Any help will be greatly appreciated.
1 ACCEPTED SOLUTION
Re: Outbound Caller ID
option 1: Set the dialplan pattern command to one number say 9728882000 with no wildcards.
option 2: Create a translation rule / translation profile to mask any source number to 9728882000 and apply that to all outbound dial peers.
voice-translation rule 1
rule 1 /.*/ /9728282000/
voice translation-profile 1
translate calling 1
dial-peer voice 1 pots
destination-pattern 9T
port 0/0
translation-profile outgoing 1
Sankar
PS: please remember to rate posts!
Gold
You have not mentioned if you have CallManager or CallManager Express. Assuming you have CallManager, you can configure the Gateway page on CM with the caller ID you want to send and this would force CM to send the same Caller ID for all Outbound calls
Sorry, I have CME 4.1. I've been looking everywhere and I can't seem to find anything. But there is always the chance I'm overlooking something. I would really like to get this finished.
translate calling 1
port 0/0
Sankar
Thank you very much, the dialplan-pattern did not work but the translation rule did. I had tried a couple variants of the translation rule but I could not get it to function correctly. I really appreciate the help.
154
