Outbound Calls Failing on FXO ports--Groundstart
I'm having issues dialing out on an FXO port.  When I dial out you can see the call work through the preferences for the voice-ports and then fail to fast busy.  The lines are ground start and I've tried several ground start options to see if it will work and am still having no success.  We have this exact same setup working at several other companies with no issues but I am having this exact same issue with two different sites for this company.  One is ground start and the other is loop start.  Inbound calls work fine, just outbound calls.  Also, I have tried stripping the 9 and 1 off of the front of the number manually but it is still not going through.  The ISP says they are not seeing the call hit the trunk group in the switch either.  Below is the pertinent configuration for one of these sites.
voice-port 0/0/0
groundstart auto-tip
signal groundStart
connection plar 6750
caller-id enable
cable-detect
voice-port 0/0/1
signal groundStart
voice-port 0/0/2
signal groundStart
voice-port 0/0/3
signal groundStart
dial-peer voice 1 pots
description DID Peer
incoming called-number .
direct-inward-dial
dial-peer voice 6750 voip
description AA
destination-pattern 6750
session target ipv4:10.101.0.4
dtmf-relay h245-alphanumeric
dial-peer voice 3600 voip
destination-pattern 36..
dial-peer voice 2200 voip
destination-pattern 22..
dial-peer voice 9 pots
preference 1
destination-pattern 9T
port 0/0/0
dial-peer voice 91 pots
preference 2
port 0/0/1
dial-peer voice 92 pots
preference 3
port 0/0/2
dial-peer voice 93 pots
preference 4
port 0/0/3
Ozark2911Voice#sho voice port sum
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxo-gs      up    up   idle     off-hook y<-------------------------------------------active outbound call.
0/0/1           --  fxo-gs      up    dorm idle     on-hook  y
0/0/2           --  fxo-gs      up    dorm idle     on-hook  y
0/0/3           --  fxo-gs      up    dorm idle     on-hook  y
0/1/0           --  fxs-ls      up    dorm on-hook  idle     y
0/1/1           --  fxs-ls      up    dorm on-hook  idle     y
0/1/2           --  fxs-ls      up    dorm on-hook  idle     y
0/1/3           --  fxs-ls      up    dorm on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Joseph,
Just to add a note here to the great tips from my buddy Deji (+5)
Can you please check the RJ11 cable to see if it is "rolled" or not. As
Ground start trunks are polarity sensitive you may need a "straight through"
cable. Have a read of this good Tech Note and you'll see this clip;
"GS signaling is polarity-sensitive, so it is important that the             T&R leads on the RJ-11 line are properly connected between the demarc point             from the CO and the FXO port on the VIC-2FXO, VIC2-2FXO, VIC2-4FXO, NM-HDA FXO,             or EVM-HD FXO equipment. If the polarity is the reverse of what it needs to be,             inbound calls from the CO to the voice router work, but outbound call attempts             from the router to the CO fail 100 percent of the time."
Troubleshoot Analog FXO GroundStart Outbound Call Failures
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00803736c1.shtml
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
VIP Super Bronze
Can you do a test call and send the ff:
1. debug voip ccapi inout
2. debug vpm signal
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: Outbound Calls Failing on FXO ports--Groundstart
Thanks for your reply.  Attached are the debugs you requested, to a local number and a few long distance numbers.
Thanks again
Your debug shows the call going out of port 0/0/3 and calling 98068798.
*Sep  3 16:38:30.018: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
*Sep  3 16:38:30.018: htsp_timer2 - 1000 msec
*Sep  3 16:38:30.018: htsp_timer_stop
*Sep  3 16:38:31.190: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
I would start by checking if the POTS line is working using an analog phone.
Please rate helpful answers!
VIP Super Bronze
In the past when I had "power denial detected" it was  a cabling issue. So I suggest you change the cables and test again
I did test from the block before running the cable and could dial out fine.  I will check the cables and see if that could be the issue.  Thanks for your response.
Hall of Fame Super Gold
For ground start lines, you need the router be grounded to earth first.
The router is grounded and we have a brand new cable running from the punch down block where the lines come in and the FXO ports on the router.  I also implemented the no supervisory disconnect signal command on each FXO line and I'm still receiving the same issue.  The call will hunt through the preferences and then fail to fast busy.
VIP Super Bronze
Power denial has plagued me for a while now. believe it or not, I had this isssue yeterday. When you plug an analogue line to the circuit it works, but when you try to make a call out I get power denial. I have arrnged to have the cable changed becaue this is what has fixed it for me in the past..
You can run this command..you need to enable term mon to see the output..
#term mon
#test voice port 0/2/0 si-reg-read 29 1----------------change port to your fxo ports
Below is the output from that command for my voice-ports.
Ozark2911Voice#test voice port 0/0/0 si-reg-read 29 1
Ozark2911Voice#
*Sep  3 17:55:27.418:
Values read from SiLabs Codec connected to DSP 0, channel 0:
Register 29 = 0x00
Ozark2911Voice#test voice port 0/0/1 si-reg-read 29 1
Ozark2911Voice#
*Sep  3 17:56:03.402:
Values read from SiLabs Codec connected to DSP 0, channel 1:
Register 29 = 0x00
*Sep  3 17:56:03.402: test voice port 0/0/2 si-reg-read 29 1
Ozark2911Voice#
*Sep  3 17:56:13.962:
Values read from SiLabs Codec connected to DSP 0, channel 2:
Register 29 = 0x00
*Sep  3 17:56:13.962: test voice port 0/0/3 si-reg-read 29 1
Ozark2911Voice#s
*Sep  3 17:56:19.850:
Values read from SiLabs Codec connected to DSP 0, channel 3:
Register 29 = 0x00
*Sep  3 17:56:19.850: ho voice port sum
                                           IN       OUT
0/0/0           --  fxo-gs      up    dorm idle     on-hook  y
VIP Super Bronze
That is your problem there..Every time you see 0x00 that suggest something is not right..
Ideally this is what you should get. or any other value other than 0x00
#test voice port 0/2/1 si-reg-read 29 1
Jul  5 15:51:02.258 GMT:
Register 29 = 0x33
I suggest you change cables first..then take it from there
Thanks for your response.  We are checking the cables today to see what could be going on.  I have a few questions though.  If inbound calls are working on those POTS lines then will the above still be true and also, I've seen several posts that indicate that this could be an issue with the PSTN's hardware in the CO.  The reason I ask is because we have two sites having this same issue and they are not very far apart so it could be assumed they are built off of the same CO switch.
Thanks for all of your help.
VIP Super Bronze
Joseph,
It is usually a difficult one. It could well be the issue is on the CO side. But the provider is going to plug a test phone to the circuit and make outbound and inbound calls..and then they tell you its not their problem..
Have you plugged a phone a phone and tested from the provider's circuit directly?
Hi Joseph,
Cheers!
Rob
- Bob Marley
I appreciate your response.  We should be checking the cabling today and will reverse the cabling to see what effect it will have.
Thanks for the reply.
We reversed the polarity of the cables and are now able to make outbound calls on all of the lines.  Thanks for your help with this.
1092
