Community Member
**OUTBOUND CALLS ISSUE WHIILE IN SRST**
Hello guys,
Few days ago i configured SRST 9.1 on a new 2951 Router, registration with sccp and sip phones went just fine but the problem were the outgoing calls,
the gw was only letting 7 digits for local calls with sccp phones while sip phones like 9971 werent calling to pstn at all just to another ephones.
Can you please help me figure out the issue??
Here is the gw config and calls debug....Thanks!
What is the called number that you are dialing out? what is the call-flow topology?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
the debug you have attached seems to be lot more calls in it? try running debugs for one and collect the same. Make sure point out the calling and called number?
Br,
Nadeem
Community Member
Thanks for your reply Nadeem,
The only extension that i had to make calls was 78077 which it is a 9971, and I was calling to locals numbers (8102737, 1180250) but all unsuccessful, We have a UCM 9 connected to a Nexus 7009 which has a trunk to a 3560X where the gateway is connected.
I think that during call fall back mode, it generates dial-peers for each extension and other 2 pointing to voice gw(172.16.0.3) and UCM (172.16.0.15). I tried with 9 at the beginning as secondary tone and the local number directly but is the same result, fast busy tone.
Jan 22 04:06:22.167: //868883/62566A9BA1B6/CCAPI/ccCallSetupRequest:
   Destination Pattern=[1-9]......, Called Number=8102737, Digit Strip=TRUE
   Calling Number=78077(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8102737(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Magdiel Sanchez
   Account Number=78077, Final Destination Flag=FALSE,
   Guid=62566A9B-8251-11E3-A1B6-D4100CF939DD, Outgoing Dial-peer=10
Jan 22 04:06:22.167: //868883/62566A9BA1B6/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=78077
   ----- ccCallInfo IE subfields -----
   cisco-ani=78077
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8102737
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 22 04:06:22.167: //868883/62566A9BA1B6/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x14F7FEB0, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=78077,(Calling Name=Magdiel Sanchez)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8102737(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE, Outgoing Dial-peer=10, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=AXTEL, tg_label_flag=2, Application Call Id=)
Jan 22 04:06:22.167: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 22 04:06:22.167: :cc_get_feature_vsa malloc success
Jan 22 04:06:22.167:  cc_get_feature_vsa count is 10
Jan 22 04:06:22.167: :FEATURE_VSA attributes are: feature_name:0,feature_time:433943056,feature_id:382306
Jan 22 04:06:22.167: //868883/62566A9BA1B6/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x1EFEC04, Call Id=868883
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Jan 22 04:06:22.167: //868884/62566A9BA1B6/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
Jan 22 04:06:22.167: //868884/62566A9BA1B6/CCAPI/ccCallSetContext:
   Context=0x10FA5124
Jan 22 04:06:22.167: //868883/62566A9BA1B6/CCAPI/ccSaveDialpeerTag:
Jan 22 04:06:22.167: //868883/62566A9BA1B6/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=AXTEL, tg_label_flag=TRUE, Call Id=0xD4213
Jan 22 04:06:22.167: //868884/62566A9BA1B6/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Jan 22 04:06:22.167: //868884/62566A9BA1B6/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Jan 22 04:06:22.167: //868883/62566A9BA1B6/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 22 04:06:22.171: //868884/62566A9BA1B6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x14F7FEB0, Tag=0x0, Call Id=868884,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   tg for this call is AXTEL success/fail is 1
   Call Disconnect Event Sent
Jan 22 04:06:22.171: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 22 04:06:22.171: :cc_free_feature_vsa freeing 19DD7208
Jan 22 04:06:22.171:  vsacount in free is 9
Jan 22 04:06:22.179: //868883/62566A9BA1B6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1EFEC04, Tag=0x0, Call Id=868883,
Jan 22 04:06:22.179: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 22 04:06:22.179: :cc_free_feature_vsa freeing 19DD81C8
Jan 22 04:06:22.179:  vsacount in free is 8
Jan 22 04:06:36.475: //868877/5C7D3AE79521/CCAPI/cc_api_call_connected:
   Interface=0x14F7AD38, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jan 22 04:06:36.475: //868876/5C7D3AE79521/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=868876
Jan 22 04:06:36.475: //868876/5C7D3AE79521/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xD420C, gcid=5C7D3AE7-825111E3-9521F872-EA8BE390, tag=0x0)
Jan 22 04:06:36.475: //868877/5C7D3AE79521/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xD420D, gcid=5C7D3AE7-825111E3-9521F872-EA8BE390, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=868876, Call Id2=868877, Tag=0x0
Jan 22 04:06:36.475: //868876/5C7D3AE79521/CCAPI/cc_api_bridge_done:
   Conference Id=0x2A828, Source Interface=0x14F7F3B0, Source Call Id=868876,
   Destination Call Id=868877, Disposition=0x0, Tag=0xFFFFFFFF
Jan 22 04:06:36.475: //868877/5C7D3AE79521/CCAPI/cc_api_bridge_done:
   Conference Id=0x2A828, Source Interface=0x14F7AD38, Source Call Id=868877,
   Destination Call Id=868876, Disposition=0x0, Tag=0xFFFFFFFF
Jan 22 04:06:36.475: //868876/5C7D3AE79521/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2A828, Destination Call Id=868877)
   Call Entry(Conference Id=0x2A828, Destination Call Id=868876)
Jan 22 04:06:36.475: confID:0x2A828; callEntry1 callID1:0xD420C, type:6; callEntry2 callID2:0xD420D, type:6
Jan 22 04:06:36.475: //868876/5C7D3AE79521/CCAPI/cc_api_caps_ind:
   Destination Interface=0x14F7AD38, Destination Call Id=868877, Source Call Id=868876,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jan 22 04:06:36.475: //868877/5C7D3AE79521/CCAPI/cc_api_caps_ind:
   Destination Interface=0x14F7F3B0, Destination Call Id=868876, Source Call Id=868877,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Jan 22 04:06:36.475: //868877/5C7D3AE79521/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5199)
Jan 22 04:06:36.475: //868876/5C7D3AE79521/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5611)
Jan 22 04:06:36.479: //868876/5C7D3AE79521/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Jan 22 04:06:36.479: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=78200, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=78200
Jan 22 04:06:36.479: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=78200, Expanded String=78200, Calling Number=
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 22 04:06:36.479: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=78000 Is Matched
   Result=Success(0); Outgoing Dial-peer=78001 Is Matched
   Result=Success(0); Outgoing Dial-peer=20045 Is Matched
   Result=Success(0) after DP_MATCH_DEST
Jan 22 04:06:36.479: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Jan 22 04:06:36.479: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20045
     2: Dial-peer Tag=78000
     3: Dial-peer Tag=78001
___________________________________________________________________________
Jan 22 04:06:39.743: //-1/6DCD93E9A1BF/DPM/dpAssociateIncomingPeerCore:
   Calling Number=78077, Called Number=98102737, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=78077
Jan 22 04:06:39.743: //-1/6DCD93E9A1BF/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Jan 22 04:06:39.743: //-1/6DCD93E9A1BF/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=78077T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 22 04:06:39.743: //-1/6DCD93E9A1BF/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=78000 Is Matched
   Result=Success(0); Incoming Dial-peer=78001 Is Matched
   Result=Success(0); Incoming Dial-peer=40141 Is Matched
   Result=Success(0); Incoming Dial-peer=40132 Is Matched
Jan 22 04:06:39.743: //-1/6DCD93E9A1BF/DPM/dpMatchPeertype:exit@6080
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40141
Jan 22 04:06:39.743: //-1/6DCD93E9A1BF/DPM/dpMatchSafModulePlugin:
Jan 22 04:06:39.743: //-1/6DCD93E9A1BF/DPM/dpAssociateIncomingPeerSPI:exit@6659
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-ani=78077
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=98102737
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x1EFEC04, Call Info(
   Calling Number=78077,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=98102737(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=40141, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=868891
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/CCAPI/ccCheckClipClir:
   In: Calling Number=78077(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=78077(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jan 22 04:06:39.747: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 22 04:06:39.747: :cc_get_feature_vsa malloc success
Jan 22 04:06:39.747:  cc_get_feature_vsa count is 9
Jan 22 04:06:39.747: :FEATURE_VSA attributes are: feature_name:0,feature_time:433947088,feature_id:382307
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=78077(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=98102737(TON=Unknown, NPI=Unknown))
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/cc_process_call_setup_ind:
   Event=0xBA07B08
Jan 22 04:06:39.747: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 98102737
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/ccCallSetContext:
   Context=0x153A3944
   >>>>CCAPI handed cid 868891 with tag 40141 to app "_ManagedAppProcess_Default"
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/ccCallSetupAck:
   Call Id=868891
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=98102737, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=98102737
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/DPM/dpMatchCore:
   Dial String=98102737, Expanded String=98102737, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=10 Is Matched
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/DPM/dpMatchSafModulePlugin:
   dialstring=98102737, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Jan 22 04:06:39.747: //-1/6DCD93E9A1BF/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/ccCallReportDigits:
   (callID=0xD421B, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Call Id=868891
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x1EFEC04, callID=0xD421B, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x1EFEC04, Call Id=868891
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
Jan 22 04:06:39.747: //868891/6DCD93E9A1BF/CCAPI/ccCallProceeding:
   Result=Success(0); Outgoing Dial-peer=100 Is Matched
   Result=Success(0); Outgoing Dial-peer=101 Is Matched
   Result=Success(0); Outgoing Dial-peer=102 Is Matched
   dialstring=98102737, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=100
     3: Dial-peer Tag=101
     4: Dial-peer Tag=102
Jan 22 04:06:39.751: //-1/6DCD93E9A1BF/DPM/MatchNextPeer:
Jan 22 04:06:39.751: //-1/6DCD93E9A1BF/DPM/dpMatchPeersCore:
Jan 22 04:06:39.751: //-1/6DCD93E9A1BF/DPM/dpMatchSafModulePlugin:
Jan 22 04:06:39.751: //-1/6DCD93E9A1BF/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=100
     2: Dial-peer Tag=10
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=98102737, Called Number=98102737, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=98102737, Expanded String=98102737, Calling Number=98102737T
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=98102737, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=98102737
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=98102737T
   Result=-1
Jan 22 04:06:39.751: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6080
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=98102737
VIP Red
Please remove the translation profile off dial-peer 10  and try again.
or create an test dial peer with  8102737  pattern without the translation.
Please remember to rate useful posts, by clicking on the stars below.
Re: **OUTBOUND CALLS ISSUE WHIILE IN SRST**
Hi.
Can you also attach a debug isdn q931 during an outgoing call?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Community Member
Thanks for your reply minkdennis and Carlo Poggiarelli,
Unfortunately box is already operating with customer and need to ask permission to let phones register in call fall back mode in order to try this changes or if there is a way to try with my phone 9971 to block register with UCM but reaching the gateway that would be great.
Anyways im gonna let you know the result of the activity
Are you using "SIP Dial Rules"?
Yosh
HTH Regards, Yosh
Community Member
Yosh we dont use SIP dial rules, any other advice?
thanks
660
