08-09-2013 05:56 PM - edited 03-16-2019 06:47 PM
I have CME 7.1 on a 2811 with a four port FXO card and 3 pots lines. I have 2 dial-peers (1 local pattern and 1 long distance pattern) for each pots dial peer. I have an ephone-dn for each pots line and each phone has a button assignment for each ephone-dn.
My question is I want to be able to press say the button assigned to ephone-dn 2 and have the call to use the number 2 fxo port.
How would I accomplish this?
Solved! Go to Solution.
08-09-2013 06:37 PM
Sorry to confuse you even more but I meant to say I did this with duplicate dial peers. Not over lapping Let me know if this works for you.
08-09-2013 06:25 PM
A little more info. For incoming calls I am using exchange unified messaging which presents a menu to direct the calls to the desired extension. Basically my overall needs are this
xxx x140 is ephone-dn 2000 and is incoming calls
xxx x434 is ephone-dn 2001 and is forwarded from an offsite pbx for incoming calls
xxx x066 is ephone-dn 2002 and the line I would prefer to be the first line for outgoing calls
Or an easier solution would be to be able to define the order of the pots lines for outgoing calls
08-09-2013 06:25 PM
Jack,
So I did this in the past with Trunk groups.
ephone-dn 288
number 3A11 no-reg primary
label CO Line1
trunk A2 monitor-port 0/1/2
There is a little more to the trunk group configuration but you should be able to find the documentaiton for it if you search
Let me know if this was helpful.
08-09-2013 06:28 PM
You second request is done much simplier
You would use the preference statement in the dial peer with overlapping dial-peers.
So basically you have overlapping dail peers that point to each port than you use the perfence statement to pick the first one.
I used to do this all the time.
08-09-2013 06:37 PM
08-09-2013 06:51 PM
Great thanks, I never thought of the preference number. Too dependent on my one remaining brain cell
