Community Member
Outbound dial peer not working
Here is my dial peer config
dial-peer voice 5 pots
description T1-CAS
service mgcpapp
direct-inward-dial
port 0/2/0:1
dial-peer voice 6 voip
destination-pattern ....
session target ipv4:10.192.9.253
dtmf-relay h245-alphanumeric
a debug shows that I am matching the inbound dial peer 5, but then I get a dial tone and fast busy on the phone. Any thoughts
thanks for your help
Community Member
Re: Outbound dial peer not working
Is this supposed to be an H323 dial peer? What are you trying to accomplish?
-Shikamaru
Community Member
No, it is an MGCP GW servicing 15 DID's with a 5 channel T1-CAS line.
Community Member
You should not be manually configuring dial peers on an MGCP gateway unless you're setting up SRST. In fact, that's kind of the point of using MGCP to begin with; it configures dial peers for you when you set up the gateway in CallManager. Your MGCP dial peer will literally look like this when CM sets it up for you;
dial-peer voice 999100 pots
application mgcpapp
port 1/0/0
dial-peer voice 999101 pots
application mgcpapp
port 1/0/1
Do NOT try to set up the above example manually, it will not work. Brush up on MGCP, it's easier than you're letting it be.
-Shikamaru
147
