Outbound dial peer selection
I have a customer with the following dial peers on a 15.1 CME router:
dial-peer voice 402 pots
corlist outgoing CORList-Mobile
description Outbound-SNPR-Mobile
translation-profile outgoing callerid
destination-pattern 98.......                   (9 digits entered)
port 0/0/0:15
forward-digits 8
dial-peer voice 404 pots
corlist outgoing CORList-TollFreeIntl
description Outbound-SNPR-TollFreeIntl
destination-pattern 9800.......                (11 digits entered)
port 0/0/0:15
forward-digits 10
The problem is that when an IP phone dials 98001101635 for example, dial peer 402 is selected instead of 404.  We have tried adding $ to the end of both peers, but behavior is the same.  It looks like the shorter pattern is matched, and selected, even though there is a longer and more specific peer available.  Is this expected behavior?  Suposedly, longest prefix is chosen, but that doesn't seem to be happening.
I think I can work around by replacing peer 402 with a pair of peers, with dest patterns
98[1-9]......
and
98.[1-9].....
This should cause 9800 to fail the match, while allowing 9801 and 9810, but is there a a simpler way?  I believe I am correct in saying that the order of the peers is irrelevant, so I can't fix it by putting peer 404 ahead of 402 in config?
Any insights would be appreciated.  Dial peer selection still seems to murky despite all the CCO doc and discussions.
1 ACCEPTED SOLUTION
Make the following change -
destination-pattern 98.......T
you see this behavior because CME does dial-peer match digit by digit, and as soon as a dial-peer is matched with an exact match, call is routed using that dial-peer
Adding T, makes the dial peer wait for more digits and introduces inter digit timeout. If you see delay in 9 digit calls, try reducing the inter digit timeout.
Udit
Hall of Fame Super Silver
Delete dial-peer 402, and re-add it, sometimes the order of them matters even though it is not suppose to. Alos, I am assuming both cor-lists are accessible, right?
Chris
Chris,
Thanks.  If memory serves, the customer did try re-ordering the peers, but I'll ask him to try again.  The cor-lists have been
checked, and should be OK
Udit
Udit,
Thanks.  I'll pass that on to the customer, and post the results
The issue was resolved - the customer ended up applying the dial-peer alterations I suggested, but I don;t knw if he tried any of the other suggestions.  Thanks to all for help.
It´s really difficult to fix
It´s really difficult to fix the problems about it on CME. For example, I have this patterns on my dial-peers:
91..    (information and emergency numbers: 107, 133, etc)
9T      (international calls and internal extensions: 123-0-525550810082, 171-0-346770810082, 17XX, 26XX)
In both of them are very similar and I understand the CME chooses the first, so I´d have the overlapping problem. How could you solve this design?
668
