OUTBOUND DIAL-PEERS NOT WORKING
On my lab, from a CorpHQ phone, when I test dial-peers for outbound dialing, only 911 & 9911 work. When I go directly to the Gateway and type the CSIM START command, the 911 pattern works and the 912065015111 NATIONAL pattern works, however the 92065015111 LOCAL pattern geta an UNASSIGNED/UNALLOCATED NUMBER error even though Dial-peer 11 is being matched. Please see the configs and debug.
Ron
___________________________________________________________________________________________________________________
dial-peer voice 10 pots
destination-pattern 911
no digit-strip
port 0/0/0:23
dial-peer voice 11 pots
destination-pattern 9[2-9]..[2-9]......$
port 0/0/0:23
dial-peer voice 12 pots
destination-pattern 91[2-9]..[2-9]......$
port 0/0/0:23
forward-digits 11
CorpHQ#
//-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=92065015111, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=92065015111
   Result=Success(0) after DP_MATCH_DEST
//-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
    1: Dial-peer Tag=11
ISDN Se0/0/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x00A6 callID = 0x8027 switch = primary-ni interface = User
CorpHQ#
ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00A6
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Called Party Number i = 0xA1, '2065015111'
                Plan:ISDN, Type:National
ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x80A6
ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x80A6
        Cause i = 0x8281 - Unallocated/unassigned number
ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x00A6
ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80A6
1 ACCEPTED SOLUTION
As stated by you, 11 pots is not working and 12 pots is working
port 0/0/0:23
port 0/0/0:23
forward-digits 11
now when i see debugs , i see that telco is sending the disconnect when your 11 pots dial-peer is hitting
in the debugs i see that , called party number is 10 digit, type :Nat and Plan:ISDN
the only diffrence that i see that is this
port 0/0/0:23
forward-digits 11
the reason above is working because your telco expects a leading digit for a 10 digit number
so when 12 pots is selected , telco is reciving "1206XXXXXXX" and telco is not reciving this in case of 11 pots
hence it is sending a disconnect
to fix this issue , simply do a prefix 1 on 11 pots and there is no way that call will not work , given the fact that 12 pots is working correctly
regards
Anurag Siddhu
Hi Ron,
You are receiving disconnect message from peer side, because you are sending called number type as "National". It should be local as per your requirement.
Please check your configuration.
However, how do you use the same number for National & Local for the same calling number?
Nishant Savalia
Regards, Nishant Savalia
Nishant:
Do you mean create a voice translation rule to change the called number type?
Ron
Re: OUTBOUND DIAL-PEERS NOT WORKING
Hi Ron,
Yes, I mean to create a voice translation profile at gateway level and apply it under the selected dial-peer.
If you don't apply any translation rule and if you are sending 10 digit as called number then IOS by default will send that number as National number. This thing happening with your current configuration.
And as you are trying for local number, it will be 7 or 8 digits. Local doesn't need area code (for e.g. 206)
What i would suggest is to check the requirement of peer or remote side because call is being released from remote end.
Also, please check the called number as you are using the same called number for National & Local as well (2065015111).
National number will be different from the local number. Please check this first.
Nishant Savalia
Hello Nishant and RON
You are completely true for Area code , and the local number (7 or 8) . Some labs for rack rental make the local calls 10 digits , as example INE rack rental the local call is 10 digits , so this is a simple lab .Please RON share your configuration , your route pattern for local call.
Thank you
please rate if this will help
CorpHQ#sh run
Building configuration...
Current configuration : 5608 bytes
version 12.4
no service pad
no service timestamps debug uptime
no service timestamps log uptime
hostname CorpHQ
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone PST -8
clock summer-time PDT recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 177.1.11.1 177.1.11.14
ip dhcp excluded-address 177.1.11.21 177.1.11.254
ip dhcp excluded-address 177.2.11.1 177.2.11.14
ip dhcp excluded-address 177.2.11.21 177.2.11.254
ip dhcp pool CorpHQ-Phones
   network 177.1.11.0 255.255.255.0
   option 150 ip 177.1.10.10 177.1.10.20
   default-router 177.1.11.1
   dns-server 177.1.100.110
ip dhcp pool Branch1-Phones
   network 177.2.11.0 255.255.255.0
   default-router 177.2.11.1
no ip domain lookup
ip multicast-routing
no ipv6 cef
isdn switch-type primary-ni
voice service voip
fax protocol cisco
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 10
rule 1 /^[2-9].........$/ /9&/
rule 2 /^1[2-9].........$/ /9&/
rule 3 /^011/ /9&/
voice translation-profile Prefix9_InFrom_CUCM
translate called 10
voice-card 0
dsp services dspfarm
archive
log config
  hidekeys
controller T1 0/0/0
pri-group timeslots 1-3,24
description == Voice Circuit to PSTN
interface Loopback0
ip address 177.1.254.1 255.255.255.255
ip pim dense-mode
interface FastEthernet0/0
description == To CorpHQ-Switch
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description == Server VLAN
encapsulation dot1Q 10
ip address 177.1.10.1 255.255.255.0
ip pim dense-mode
interface FastEthernet0/0.11
description == Voice VLAN
encapsulation dot1Q 11
ip address 177.1.11.1 255.255.255.0
ip helper-address 177.1.10.10
ip nbar protocol-discovery
ip pim dense-mode
interface FastEthernet0/0.12
description == Data VLAN
encapsulation dot1Q 12
ip address 177.1.12.1 255.255.255.0
interface FastEthernet0/0.13
description == PSTN PHONE VLAN
encapsulation dot1Q 13
ip address 177.1.13.1 255.255.255.0
interface FastEthernet0/1
description === To PSTN
ip address 177.1.19.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/0
description == Frame-Relay Circuit to WAN
no ip address
encapsulation frame-relay
fair-queue 64 256 36
cdp enable
frame-relay lmi-type ansi
ip rsvp bandwidth
interface Serial0/1/0.1 point-to-point
description == FR To BR1
bandwidth 384
ip address 177.0.101.1 255.255.255.0
ip pim dense-mode
snmp trap link-status
frame-relay interface-dlci 101
ip rsvp bandwidth 136
interface Serial0/1/0.2 point-to-point
description == FR To BR2
ip address 177.0.201.1 255.255.255.0
frame-relay interface-dlci 102
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 177.1.19.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0.10
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:23
voice-port 0/3/0
voice-port 0/3/1
ccm-manager music-on-hold
sccp local Loopback0
sccp ccm 177.1.254.3 identifier 3 priority 3 version 5.0.1
sccp ccm 177.1.10.20 identifier 2 priority 2 version 5.0.1
sccp ccm 177.1.10.10 identifier 1 priority 1 version 5.0.1
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate ccm 3 priority 3
associate profile 3 register CorpHQ-HW-Xcode
associate profile 2 register CorpHQ-711-MTP
associate profile 1 register CorpHQ-729-MTP
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec ilbc
maximum sessions 2
associate application SCCP
dspfarm profile 1 mtp
codec g729ar8
codec g729r8
rsvp
maximum sessions software 10
dspfarm profile 2 mtp
codec g711ulaw
rsvp
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
no digit-strip
port 0/0/0:23
port 0/0/0:23
port 0/0/0:23
forward-digits 11
dial-peer voice 100 voip
description == Inbound/Outbound SIP PSTN GW From/To CUCM Pub
translation-profile incoming Prefix9_InFrom_CUCM
destination-pattern ^2065011...$
voice-class codec 1
session protocol sipv2
session target ipv4:177.1.10.10
ip qos dscp cs3 signaling
dial-peer hunt 1
sip-ua
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous level 0 limit 20
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
no login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
scheduler allocate 20000 1000
ntp source Loopback0
ntp master 2
ntp server 177.1.254.254
end
Hello
Can you use the below configuration and try again.
voice translation-rule 2
rule 1 // // type any subscriber plan any isdn
voice translation-profile local
translate called 2
translation-profile outgoing local
forward-digits 10
port 0/0/0:23
if this not work , please share with us your all configuration. Tell us also please this configuration for  CME , or CUCM and H323 GW .
Thank you
please rate all useful information
Hi Islam:
The voice translation rule didn't work. Please see the following...
Hall of Fame Super Silver
Did you verify that the number is dialable as 10 digits and not 7 digits or 11 digits for example?
Chris
Hi Ron.
Can you please post you actual running config?
Carlo
Please rate all helpful posts "The more you help the more you learn"
CorpHQ#sh run
version 12.4
no service pad
hostname CorpHQ
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice service voip
fax protocol cisco
sip
voice class codec 1
rule 3 /^011/ /9&/
--More--
%PIM-5-NBRCHG: neighbor 177.0.101.2 UP on interface Serial0/1/0.1
%OSPF-5-ADJCHG: Process 1, Nbr 177.1.254.3 on Serial0/1/0.2 from LOADING to FULL, Loading Done
%OSPF-5-ADJCHG: Process 1, Nbr 177.1.254.2 on Serial0/1/0.1 from LOADING to FULL, Loading Done
translate called 10
voice-card 0
archive
log config
  hidekeys
controller T1 0/0/0
interface Loopback0
ip pim dense-mode
no ip address
duplex auto
speed auto
ip pim dense-mode
ip pim dense-mode
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
no ip address
cdp enable
ip rsvp bandwidth
bandwidth 384
ip pim dense-mode
router ospf 1
no ip http server
control-plane
voice-port 0/0/0:23
voice-port 0/3/0
voice-port 0/3/1
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec ilbc
maximum sessions 2
codec g729ar8
codec g729r8
rsvp
codec g711ulaw
rsvp
direct-inward-dial
no digit-strip
port 0/0/0:23
port 0/0/0:23
port 0/0/0:23
forward-digits 11
voice-class codec 1
dial-peer hunt 1
sip-ua
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
no login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
ntp master 2
end
port 0/0/0:23
port 0/0/0:23
forward-digits 11
port 0/0/0:23
forward-digits 11
regards
Anurag Siddhu
Anurag:
Excellent job!. It worked, however could this have been corrected in the PSTN configuration instead? I don't want to encounter this issue again...
Many thanks,
Ron
yes, if you are simulating this in lab scenario , you can change this config on Telco router and this can be fixed.
if this is real time scenario, you have to contact your telco provider in order to change this.
It is a lab, however I am just a novice with voice translation-rules. I wouldn't have a clue what to change on the PSTN router.
you can send me the sh run , i can help you with that if you wish
Hi Anurag:
Please see the following PSTN router config. BTW, what is the best resource to learn voice translation-rules?
Thanks again,
Ron
____________________________________________________________________________________________-
PSTN#sh run
Current configuration : 13974 bytes
! No configuration change since last restart
version 12.4
no service pad
hostname PSTN
boot-start-marker
boot-end-marker
card type e1 0 0
card type t1 0 1
no aaa new-model
clock timezone EST -5
clock summer-time EST recurring
network-clock-participate wic 1
no network-clock-participate aim 0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip domain name att.com
ip name-server 177.1.100.110
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol cisco
sip
  bind control source-interface Loopback10
  bind media source-interface Loopback10
  header-passing
voice translation-rule 101
rule 1 /^\+.*/ //
rule 2 /^501.*/ //
rule 3 /^1206.*/ //
rule 4 /^00.*/ //
rule 5 /^0011.*/ //
rule 6 /^206/ /1&/
rule 7 /^1512.*/ /&/
rule 8 /^011\(31.*\)/ /\1/
voice translation-rule 102
rule 1 /^1\(2065015111\)$/ /\1/ type any subscriber plan any isdn
rule 2 /^1\(2065015555\)$/ /\1/ type any subscriber plan any isdn
rule 3 /^1\(2065015151\)$/ /\1/ type any subscriber plan any isdn
rule 4 /^1\(5126026222\)$/ /\1/ type any national plan any isdn
rule 5 /^31670357575$/ /&/ type any international plan any isdn
rule 6 /^31207037333$/ /&/ type any international plan any isdn
rule 7 /^31107047444$/ /&/ type any international plan any isdn
rule 8 /^911$/ /&/ type any unknown plan any unknown
rule 9 /^15126022.../ /&/ type any unknown plan any unknown
rule 10 /^31207033.../ /&/ type any unknown plan any unknown
rule 11 /^....$/ /&/ type any unknown plan any unknown
voice translation-rule 103
rule 1 /^206.*/ /&/ type any subscriber plan any isdn
rule 2 /^1/ // type any national plan any isdn
rule 3 /^00/ // type any international plan any isdn
voice translation-rule 201
rule 1 /^\+.*/ //
rule 2 /^602.*/ //
rule 3 /^1512.*/ //
rule 4 /^00.*/ //
rule 5 /^0011.*/ //
rule 6 /^512/ /1&/
rule 7 /^1206.*/ /&/
voice translation-rule 202
rule 1 /^1\(5126026222\)$/ /\1/ type any subscriber plan any isdn
rule 2 /^1\(2065015555\)$/ /\1/ type any national plan any isdn
rule 3 /^1\(2065015151\)$/ /\1/ type any national plan any isdn
rule 4 /^1\(2065015111\)$/ /\1/ type any national plan any isdn
rule 9 /^12065011.../ /&/ type any unknown plan any unknown
voice translation-rule 203
rule 1 /^512.*/ /&/ type any subscriber plan any isdn
voice translation-rule 301
rule 1 /^\+.*/ //
rule 2 /^20.*/ //
rule 3 /^0\([1-8].*\)/ /31\1/
rule 4 /^011/ //
rule 5 /^0031/ //
rule 6 /^703..../ /3120&/
rule 7 /^00\(1.*\)/ /\1/
voice translation-rule 302
rule 1 /^31207037333$/ /7037333/ type any subscriber plan any isdn
rule 2 /^7033\(...\)$/ /0207033\1/
rule 3 /^911$/ /112/ type any unknown plan any unknown
rule 4 /^31\(670357575\)$/ /0\1/ type any national plan any isdn
rule 5 /^31\(107047444\)$/ /0\1/ type any national plan any isdn
rule 6 /^12065015555$/ /&/ type any international plan any isdn
rule 7 /^12065015151$/ /&/ type any international plan any isdn
rule 8 /^12065015111$/ /&/ type any international plan any isdn
rule 9 /^15126026222$/ /&/ type any international plan any isdn
rule 10 /^12065011...$/ /&/ type any unknown plan any unknown
rule 11 /^15126022...$/ /&/ type any unknown plan any unknown
rule 12 /^....$/ /&/ type any unknown plan any unknown
voice translation-rule 303
rule 1 /^703.*/ /&/ type any subscriber plan any isdn
rule 2 /^010/ // type any national plan any isdn
rule 3 /^1/ // type any international plan any isdn
voice translation-rule 1000
rule 1 /.*\(1...$\)/ /206501\1/
rule 2 /.*\(2...$\)/ /512602\1/
rule 3 /.*\(45..$\)/ /020757\1/
voice translation-rule 1001
rule 1 /^1206...5...$/ /+&/
rule 2 /^1512...6...$/ /+&/
rule 3 /^31.0...7...$/ /+&/
voice translation-profile 1-HQ-Change_DNIS-Check_ANI
translate called 101
voice translation-profile 1-HQ-Proper_Types
translate calling 102
translate called 103
voice translation-profile 2-BR1-Change_DNIS-Check_ANI
translate called 201
voice translation-profile 2-BR1-Proper_Types
translate calling 202
translate called 203
voice translation-profile 3-BR2-Change_DNIS-Check_ANI
translate called 301
voice translation-profile 3-BR2-Proper_Types
translate calling 302
translate called 303
voice translation-profile SIP-NORMALIZE-DNIS-ANI
translate calling 1001
translate called 1000
voice-card 0
dspfarm
archive
log config
  hidekeys
controller E1 0/0/0
clock source internal
pri-group timeslots 1-3,16
description == Voice Circuit to Branch2
controller T1 0/1/0
cablelength long 0db
description == Voice Circuit to CorpHQ
controller T1 0/1/1
description == Voice Circuit to Branch1
interface Loopback0
ip address 177.1.254.254 255.255.255.255
ip address 177.1.254.250 255.255.255.255
interface Loopback11
ip address 177.1.254.251 255.255.255.255
description ==TO INTERNET==
ip address 192.168.1.150 255.255.255.0
duplex auto
speed auto
description === To HQ
ip address 177.1.19.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
description == PRI Circuit to R3-BR2
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn protocol-emulate network
isdn negotiate-bchan resend-setup
no isdn outgoing ie network-facility
isdn outgoing display-ie
no cdp enable
interface Serial0/1/0:23
description == PRI Circuit to R1-HQ
no ip address
encapsulation hdlc
isdn switch-type primary-5ess
no cdp enable
interface Serial0/1/1:23
description == PRI Circuit to R2-BR1
no ip address
encapsulation hdlc
isdn supp-service name calling
no cdp enable
router ospf 1
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http authentication local
ip http path flash:
control-plane
voice-port 0/0/0:15
translation-profile incoming 3-BR2-Change_DNIS-Check_ANI
description == Voice PRI to Branch2
voice-port 0/1/0:23
translation-profile incoming 1-HQ-Change_DNIS-Check_ANI
description == Voice PRI to CorpHQ
voice-port 0/1/1:23
translation-profile incoming 2-BR1-Change_DNIS-Check_ANI
description == Voice PRI to Branch1
description == All inbound calls from HQ BR1 BR2 into PSTN
direct-inward-dial
dial-peer voice 101 pots
description == Subscriber Calls from PSTN into CorpHQ
translation-profile outgoing 1-HQ-Proper_Types
preference 1
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 102 pots
description == National Calls from PSTN into CorpHQ
preference 1
destination-pattern ^12065011...$
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 103 pots
description == International Calls into CorpHQ from PSTN Coming from NL Ph
preference 1
destination-pattern ^0012065011...$
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 104 pots
description == + Calls into CorpHQ from PSTN Coming from Mobiles
preference 1
destination-pattern +12065011...$
direct-inward-dial
port 0/1/0:23
forward-digits 10
dial-peer voice 201 pots
description == Subscriber Calls from PSTN into Branch1
translation-profile outgoing 2-BR1-Proper_Types
preference 1
destination-pattern ^5126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 202 pots
description == National Calls from PSTN into Branch1
preference 1
destination-pattern ^15126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 203 pots
description == International Calls into Branch1 from PSTN Coming from NL Ph
preference 1
destination-pattern ^0015126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 204 pots
description == + Calls into Branch1 from PSTN Coming from Mobiles
preference 1
destination-pattern +15126022...$
direct-inward-dial
port 0/1/1:23
forward-digits 10
dial-peer voice 301 pots
description == Subscriber Calls from PSTN into Branch2
translation-profile outgoing 3-BR2-Proper_Types
destination-pattern ^7033...$
direct-inward-dial
port 0/0/0:15
forward-digits 7
dial-peer voice 302 pots
description == National Calls from PSTN into Branch2
destination-pattern ^0207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 10
dial-peer voice 303 pots
description == International Calls into Branch2 from PSTN Coming from US Ph
destination-pattern ^01131207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 9
prefix 0
dial-peer voice 304 pots
destination-pattern ^31207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 9
prefix 0
dial-peer voice 305 pots
description == + Calls into Branch2 from PSTN Coming from Mobiles
destination-pattern +31207033...$
direct-inward-dial
port 0/0/0:15
forward-digits 9
prefix 0
dial-peer voice 1000 voip
description == Calls into AT&T SIP ITSP for VC Week1 Lab1
rtp payload-type nse 99
rtp payload-type nte 100
voice-class sip localhost dns:sip1.att.com
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5000 voip
service aa
destination-pattern A5000
session target ipv4:177.1.254.254
incoming called-number A5000
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
num-exp 1888....... 911
num-exp 1900....... 911
num-exp 1976....... 911
num-exp 1777....... 911
num-exp 1444....... 911
num-exp 0800....... 911
num-exp 0900....... 911
sip-ua
telephony-service
no auto-reg-ephone
max-ephones 1
max-dn 10
ip source-address 177.1.254.254 port 2000
caller-id block code *67
system message You WILL PASS this Exam!
voicemail A5000
max-conferences 8 gain -6
call-forward pattern .T
dn-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Sep 01 2012 15:29:37
ephone-dn  1  dual-line
number 12065015111 secondary +12065015111
label Seattle, US +1 206 501 5111
description INE PSTN Phone
name Seattle US Phone
ephone-dn  2  dual-line
number 15126026222 secondary +15126026222
label Austin, US +1 512 602 6222
name Austin TX Phone
ephone-dn  3  dual-line
number 31207037333 secondary +31207037333
label Amsterdam, NL +31 20 703 73 33
name Amsterdam NL Phone
ephone-dn  4  dual-line
number 12065015555 secondary +12065015555
label Hurley Mobile +1 206 501 5555
name Hurley's Mobile
call-forward busy A5000
call-forward noan A5000 timeout 16
ephone-dn  5  dual-line
number 12065015151 secondary +12065015151
label Hurley's Home +1 206 501 5151
name Hurley's Home
call-forward noan A5000 timeout 12
ephone-dn  6  dual-line
number 31670357575 secondary +31670357575
label Sawyer's Mobile +31 6 70357575
name Sawyer's Mobile
ephone-dn  7  dual-line
number 911 secondary 112
label US/EU Emer/FreePhone/Prem
name Emergency Services
ephone-dn  8  dual-line
number 15126026262 secondary +15126026262
label BLinus Mobile +1 512 602 6262
name Benjamin Linus Mobile
ephone-dn  9  dual-line
number 31207037373 secondary +31207037373
label DHume Home +31 20 703 73 73
name Desmond Hume Home
ephone-dn  10  dual-line
number 31107047444 secondary +31107047444
label Rotterdam, NL +31 10 704 74 44
name Rotterdam NL Phone
ephone  1
device-security-mode none
mac-address A456.3040.0DAA
type 7975
button  1:1 2:2 3:3 4:10
button  5:6 6o7,8,5,4
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
no login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
ntp master 10
ntp server 64.90.182.55
end
I have that .pdf
Hi Anurag:
Thanks again for your assistance. Regarding your fix for the CorpHQ router whereby I had to prefix a '1' on dial-peer 11, I ran into the same issue with Branch1. When I ran a debug isdn q931 on Branch1, the local CALLED number looked normal 5126066222. It correctly stripped the '9' and sent the call out as an E.164 compliant number, however the call didn't route because a '1' wasn't prefixed, so went to the Called Party Transformation Pattern for that number and prefixed a '1' and now the call routes properly, however, I would like to fix this problem from the PSTN router side because I shouldn't have to be prefixing a '1' to route a local call. Can you assist with this? This is not an urgent matter, however, I only have very basic knowledge of voice translation-rules at this juncture and I will not be able to rectify the problem without assistance.
Ron
Just go this this below rule on telco
rule 1 /^\+.*/ //
rule 2 /^501.*/ //
rule 3 /^1206.*/ //
rule 4 /^00.*/ //
rule 5 /^0011.*/ //
rule 6 /^206/ /1&/
And modify the rule 6 to either of the below mentioned
Rule 6 /^206.......$/ /1&/
Or rule 6 /^206.*/ /1&/
And let me know if either of this worked or not , if not then we will try something else
Anurag siddhu
Hi Anurag:
For both of the voice-translation rules, there is an invalid input pointing to the the number '1'. It doesn't like the '1' preceding the ampersand.
PSTN(config)#voice translation-rule 101
PSTN(cfg-translation-rule)#rule 6 /^206.......$/ /1&/
% Invalid input detected at '^' marker.
PSTN(cfg-translation-rule)#rule 6 /^206.*/ /1&/
it didn't paste properly, but the error was pointing to the '1'....
sorry about that
the rule is this , may be it got mistyped as i sent it from my ipad
rule 6 /^206......$/ /1&/
or
regards
Anurag Siddhu
Hi Anurag:
Neither of the translation-rules worked. Earlier you fixed my call routing problem when you suggested I prefix a '1' in the dial-peer. At this time, I can move on with my lab. Unless you are still interested in resolving this PSTN issue, I will no longer inconvenience you.
Thank you for all of your efforts,
Ron
1281
